Here we go, I'm getting geared up to rebuild my 48RE (2006 2500). There is so much confusion in my mind on various trans components, wondering if anyone had any input on:
1. I see that Sonnax has a smart input that comes with a piston and you can install an extra friction, is there any reason not to get this Sonnax vs. just a plain billet input shaft? The price is not a factor for me between the two. I'm going to do the input because if I'm pulling the trans, why not unless the stock can hold up to 450-500HP safely?
https://www.sonnax.com/parts/3937-smart-tech-high-capacity-input-shaft-piston-kit
https://www.sonnax.com/parts/1818-heavy-duty-input-shaft
2. Anyone use cascade trans parts, they use Excedy frictions, are Excedy frictions good?
3. Single disc vs triple disc and the flex plate issue. I would like to make up to 450-500HP. Everywhere I read I see conflicting information when you need a flexplate and when you need a triple disc converter. I'm not sure what to think.
4. Any good tips on daily driver stall speed on converter?
5. Also thinking on valve body, shift kit, etc.
