Yes i've googled, and searched everywhere and can't seem to find anybody that has experienced this issue.
Just did the G56 swap on my 2006 Dodge Ram 2500 Mega Cab 5.9, everything was swapped correctly without any issues. Wired up the clutch safety switch properly because when I try and turn the truck over it makes one click when the clutch pedal is pressed in, and when it isn't pressed there is no click or anything.
I was getting a code P0513 (invalid skim key) but that isn't the case, i just had a locksmith out here today to reprogram the truck and turns out the key was still programmed correctly. He was saying that it could be a bad BCM, but since the '06 2500's don't have BCM's from what I've gathered on other forums, I have no idea what to do next.
When i turn the truck on, the radio thinks it's in reverse regardless of whether or not I press the clutch pedal in. I'm wondering if the ECM thinks the truck is still in reverse and that's why it wont even consider cranking the starter. If i have it towed to the stealership and they flash the ecm to a manual, will that fix the issue with the no crank? I've read where people can still drive the truck without flashing the ecm but it just shows the PRNDL and throws codes relating to the transmission.
If anyone can please help asap I would appreciate it very much, I need to get this thing running since it's my daily and my wife is getting tired of me driving her car all the time lol
