Stock trans ?
mileage?
check fluid/filter / debris in pan?
bands/shift cable adjusted properly?
triple check wiring , wont always throw codes.
OEM transducer/GPS are junk, hopefully used Rostra
50-1017
and Borg Warner 50185 upgrade, should perform proper pressure test with real gauges because of this.
ECM controls TTVA was it initialized?
The Transmission Throttle Valve Actuator (TTVA) does not require any mechanical adjustments. All changes in throttle
valve position are controlled by the Engine Control Module (ECM).
The TTVA does require an initialization period after the actuator has been removed or replaced. After the actuator
has been removed or replaced, move the ignition to the ON position for thirty (30) seconds. This will allow the ECM
sufficient time to perform the internal calibration procedures to learn the TTVA’s current “zero” position. Once this is
done, check the ECM for diagnostic trouble codes (DTCs). If no DTCs are set relating to the TTVA, the TTVA is fully
calibrated and ready for use.
