Off the top of my head: OD direct clutch pack going bad. Rear band bad or slipping. Rear servo jamming in bore. Forward clutch pack slipping.
It is not the same problem if you have all the forward gears. If you have manual first and no reverse it is the OD direct clutch pack toasted. That will take some tools and knowledge to rebuild correctly.Im having the same problem. Only mine as completely stopped going backward. All forward gears are fine. how difficult is the replacement process??? Is it something a novice can perform?
Mine didnt slip. It just stopped going in reverse. I can feel it go into gear but it doesnt move. Took it to a transmission mechanic friend who checked it, said everything electrically is fine and that the servo is probably the cause of the problem. Just wondered how difficult it would be to replace it myself instead of paying $200 labor.
Thanks.
