1 - 20 of 95 Posts
Discussion Starter #2
2004 48RE with TV cable
this kit can be used from 2003 to 2007 as long as it is the 48RE valve body
the customer just wanted improved performance from his trans and a little better for towing, this kit is going to be install right out of the box no tips or tricks extras or all out performance. That is all the customer wanted . Next time I do one if it is different I will post updates.
shift kit I know it says 2005 and newer but it fits all 48RE valve bodies
48RE VB
47RE VB
govenor block and solenoids removed
boost valve cover and shuttle valve cover removed , rooster comb pressure regulator and switch valve removed
all screws removed and seperate into 3 pieces
don't lose this little ball
main body 7 check balls
one large six small
little jig included in kit to cut a channel in the manual valve bore
channel cut
bottom of pressure reg bore scribe a line
line
remove plug and drill .055" hole
reinstall plug after cleaning
Discussion Starter #5 (Edited)
new TV valve line up, valve and spring included in kit
assembled
remove TV limit body
switch out spring from kit
remove cover
remove shuttle valve , spring and plug... replace red spring with white from kit
installing clip on shuttle valve
replace boost valve clip and cover with new cover supplied
clips LOVE to break and the new cover has an updated orfice size
installed
dissasemble channel plate section of VB
notice 2 check balls the one on the lower right corner was missing (snow plow trans) customer was complaining of a rude revers .. this was the problem just put in a check ball softens up reverse engagment a bit
drill small hole to .109" to speed up revese engagment a bit
drill .109" I think this speeds up 3rd apply
drill .055" helps with LU apply I sometimes go bigger but on a 48RE it may "POP" a bit if you do or if you have a low stall converter it may "POP" a bit as well
reassemble don't forget filter also try to line up the holes as best you can
check balls notice one left out
notice guide bolts (cut off filter screws)
drop channel plate over guide pins, install small check ball , I like to glue it in with a dab of assembly grease
upper VB on guide pins
one screw has a different washer in it
goes here, reinstall the rest of the screws
4th accumulator and spring
accululator cover, boost tube upright in vise for easier assembly
tube with tabs bent over
pressure regulator valve and switch valve
springs blue spring is from shift kit
this is pressure regulator spring retainer in the stock position
adjusted as per shift kit , the blue spring is much stiffer this adjustment is a higher line pressure than the stock setup
Discussion Starter #8
installed
I usually install the TV rod and rooster comb before the pressure reg but I got distracted
the manual valve was supplied in the kit
stock govenor body
modded
BW gov solenoid on right stock on left
better pic
installed see the clearance for oil to properly circulate
clip plugs in upside down with the BW solenoid so make sure the wire has slack and the connector is out of the way of the bracket
better
metal rings supplied installed on accumulator
pink spring supplied in kit , grey is stock
orfice cup plug for accululator bore
install in hole , flush with case
stick springs to accumulator helps assembly a bit
ok thats all there is to it
install the VB back into the trans , adjust bands , fresh filter and oil
POSSIBLY if you have a TV cable you mave need to make an adjustment , I have had a few where there is a bit too much TV pressure and the trans will downshift from 4th to 2nd at too high of speed and put the engine on the govenor
this kit worked AWESOME the truck had a stock converter it was crisp but not at all rude under all throttle conditions
I sell this kit in all my rebuilts usually with a single billet and superior super intermediate servo and billet band strut
I wouldn't be scared to run 100HP tune all day long with that setup
subscribing for future use.
I can't find the difference in the 47re/48re vb's. I have to switch back and forth between the pictures as I can't see them on my screen at once. Can you point it out? Thanks
Wow! I'll try most DIY projects, but after seeing this I think I'll leave it up to the professionals.
Nice writeup though!
I agree with megasmoke, ive been wanting to do this among V/B, T/C (new i wasnt going to do that). How long did it take you to complete this?
Reactions: 59turbo
Yeah if I have to start drilling and notching stuff on the valve body to make it work I think I will leave it to someone else. I would really love to have it done for sure though
how was it dropping the valve body and adjusting the bands how straight forward is this my dads buddy has a tranny shop and is selling me a valve body with a shift kit and all i have to do is swap them out how straight forward is it gonna be and wat about adjusting the bands?
Thanks
Phil
Discussion Starter #15
this is for the 48RE
not sure if I have a pic of the difference
it's just one spot you need to know where to look
Discussion Starter #16
it's the first two VB pics if yours looks like the top pic its a 48 if it looks like the bottom it is a 47
the missing slot on the right end of that bore is what were looking for
Great demo Baxi. My question is if I send you my VB, how much to do all that cool stuff to it then mail it back for me to install?
Also, are you replacing that week band that goes around the drum. My tranny guy replaced it while on the truck by grinding away a small portion of the band. It worked okay for a couple thousand miles but now does the same thing. Second gear slip and lazy shifting. It help would be appeciated..Mike
Assuming it's finished, what's the end result on the performance increase?
Discussion Starter #19
I live in Canada so not so economical to ship it across border twice
1 - 20 of 95 Posts
