My tranny has always felt a little bit sloppy. But the last few weeks it has been down shifting hard into 2nd and 1st gear mostly when it is not fully to operating temp. It shutters into over drive when at 3/4 or more throttle. There is no metal in fluid and it is not discolered. I went to adjust my front band there is no adjustment left. Wil the band make it act like this?:confused013: I recently dropped the pan to do a service wich was not needed as i have done it 2times before this within 15k. I replaced the governor press and the trans temp sensor it helped that was what the code came up as. It shifts ok other than the shuddering :banghead:. I have been priced 2,100$ for a rebuild with all the updates and the converter would be a billet drum converter from transco according to the tranny shop. Any input will be appreciated thanks.
