1 - 20 of 41 Posts
shifter seal
accumulator 4 ring with pink shiftkit spring
installed
reverse servo installed
super srevo
super servo sleeve installed
install servo
install stock spring then cover I use c-clap vise grips
OD piston support and gasket
loctite bolts torque to 105 in/lbs
low/reverse band anchor
low sprag
low/reverse band
low drum
repacement thrust washer made of metal
thrust washer installed with snap ring
output seal
Good stuff man.
Discussion Starter #3 (Edited)
output shaft and drum
installed
thrust washer only goes one way be careful
then sprag only goes one way
inner race
lube sprag with ATF
OD planet
OD sun gear with new bearing and plate replaced every rebuild
notice updated bushing in new sun gear
bearing only goes one way
grease liberally to aid in assembly
spring
OD direct clutch hub
home made alignment shaft
installed for assembly
compression tool in press
press far enough to install ring, some builders do the OD direct clutch at the same time but I dont
OD direct reaction plate step goes down
OEM 48RE OD direct clutch on left the change up on the right
single sided clutches hold great but don't take the heat during shifts
stack up as shown pressure plate on top step up
back to the compressor
new snap ring every rebuild
use tool as a stand
slide case over assembly look thru access hole
spread ring until case slides over
lift up on case until snap ring POPS into groove as shown
cover and gasket
use tool as stand again
single snap ring (47RE uses a flat and wave)
pressure plate step down
stack up clutches
stick bearing to hub with grease, poor pic but notice another OD steel installed on top of last one in clutch pack , leave out wire retaining ring at this time
OD clutch clearance selectable shim
place piston on clutch pack the cearance shown with the pick should be about .010 to .015" for best results (stock is usually around .025") adjust with selective shim shown in last pic
remove extra steel and install wire retaining ring
these have to align when installed notice
at this point the pin shown in previous pic will be aligned with hole test by turning piston back and forth it should just move slightly , this is the tool I use to install lip seals work around until seal slides in don't be in a hurry or force it (tool is actually a smoothed drawer removal tool from my old snap on tool box)
installed fully
intall a new gasket and bolt OD housing to main case
to be continued Tuesday evening
Cool!!! Mine next please!
Reactions: Phillipjon
This is perfect. I'm doing mine right away.
Make a video. Haha
The last like 12 pics don't work??
Discussion Starter #11
intermediate shaft rear ring gear
rear planet ALWAYS replace thrust washers they wear out quickly on 48RE
washer on top same as bottom
sun shell new washer notice how thick the 48RE sun shell is
front planet new washer
front ring gear specific to 48RE don't forget plastic insulator
snap ring , make sure you have a little bit of end play just a wiggle aprox .010" if it is much higher something is worn out (thrust washer or rear ring gear usually)
usually some wear here where the ring sits on the shaft causing high endplay
input shaft or rear clutch
this is what I use to lube o-rings and lip seals works great
work it in carfully with a tool to get that lip seal down
slide input shaft thru clutch retainer
belvil return spring
spacer then waved snap ring
the silver washer is an endplay shim you can get from superior shift technologies
backing plate step down against belvil
start stacking up forward fibers
snap ring is selevtive if you need to make an adjustment , this clutch runs tight but you should still be able to turn the fibers fairly easily
washer and rings
front clutch or direct drum
OEM inner seal and updated inner seal I have no idea why both are included in the kit use th wider one if it didn't come in your kit most shift kits include it
install outer seal on piston , lube it up and shimmy it in no tools required
Discussion Starter #12
foot press that I use , use your ingenuity to compress return springs and get snap ring back on
install fibers and steels , resist the urge to tighten up the clearance here they run loose , if you bing down the clearance when you put it in reverse you may get a BANG apply because the drum will apply before the band does causing the geartrain to rotate before the band holds it
clearance notice I changed to a thicker non wave snap ring , I know it might make it pop a bit when it shifts but the thick ring is much stronger
install direct drum over input shaft
Discussion Starter #13
wiggle and jiggle until input shaft fits in
check everything engages
intermediate band
installed top view
superior strut comes with the super servo kit make sure you dont intall it upside down it fits easily but POPS off when you put the VB on (not that I know from experience)
adjuster
alignment pins and pump gasket lube the case for O-ring
cleaned up pump body
bushing make sure it has the dimples .. a solid one witll be eaten up by a 48RE converter hub
drive it home sometimes I loctite it in
stake bushing
seal with green loctite
lube seal and bushing at this time
Discussion Starter #14 (Edited)
lube and install gears
pack with grease to create good pump sucktion at start up
pump bolts 21 ft/lbs **** use torque wrench very easy to warp ****
washer and rings
stator washer found on 48RE ... there is some debate over the use of a 47RE stator being stronger because there is no groove machined here ... some guys say that the added strength is worth giving up a small amount of converter pressure , I have used both stators interchangably without any problem ... I probably wouldn't switch it if I was putting in a stock torque but with a good single or triple billet I wouldnt worry about it at all
lube o-ring
carfeull install .. don't hammer it should pop in with a little hand force
Discussion Starter #15 (Edited)
pump bolts and seal washers torque to 21 ft/lbs
endplay I like .015 to .010 but the spec is WAY higher if you have NONE then you may be hung up on a forward fiber OR one of the bearings in the OD unit is upside down
THIS IS MY OPINION ON BAND ADJUSTMENT if you are not comfortable with it use the factory manual to adjust bands
Discussion Starter #16
on front band adjustment I like 1/4"
accumulator spring
better pic of shift kit cup plug
park rod feed it in and wiggle output shaft until it pops into place
hook VB on park rod
clip
torque bolts to 105 in/lbs , notice BW gov solenoid
filter
pan
speed sensor
Man... last time I cracked open an auto tranny, it seemed at the time to be much more complex than that... these pics probably make everything look easier than it really is... but its tempting me to rebuild mine myself.
I'm not a mechanic by trade, but I've done a lot of different things on cars and trucks as far as mechanics go (new heads, cams, turbo swaps etc). I'm of a very mechanical mindset and am familiar with the proper practices with antiseize, locktite, torqueing etc... and have a pretty solid set of tools.
Would this be something you'd strngly suggest against for a tranny newb like me? My transmission has been into dodge umpteen jillion times, and they refuse to fix whats not completely broke. It shuttles on/off throttle and into 3rd. Also feels like there is slippage. (Dealer has replaced kickdown bands, new solenoids and a new valvebody, and they assured me the clutch bands were fine).
Its a 2004.5 and has 44k mi on it. I dont expect it to drive and shift like a cadillac, but I am sure other people with equivalent truck... have much more pleasurable driving experience...
opinions?
Sticky this! Awesome pics! Thank you!
World Champs!!!
1 - 20 of 41 Posts
