2006 Ram 2500 ; 188,000 miles - all stock
Transmission was rebuilt at about 133,000 miles by a local transmission shop. During that time the torque converter and clutch’s were replaced.
I just recently lost OD. It will intermittently shift into OD while in tow/haul mode. No codes.
This is a picture of the pan. Shop states it needs another rebuild. Any ideas or suggestions?
Thank you in advance!
Looks like it's been a hot minute since it was serviced. Check for codes and make sure to adjust the bands. See what that yields.
I will check for codes again and adjust the bands. Would a flush be recommended as well? Is that a normal amount of metal on the magnet?
I think there are some steels in the clutch packs well chewed up with that much metal. Probably need to tea rit down and assess.
If it’s running and shifting, agree with above. Change the fluid and adjust both bands. Worst case is you’ll be out a few bucks for fluid if you have to have a rebuild.
Thank you for all the suggestions. I’m going to change the fluid and adjust the bands. I’ll drop the pan again after a few thousand miles (if it makes it that long) and reassess.
06 Ram 2500
Do you know if the solenoids were changed out?
If you mean you lost od by it not shifting into od it could be solenoid is bad or plugged up, I think somewhere there's an ohm spec for it to see if the coil is still good. You can also pull out the solenoid and see if there's junk on it too.
If your od just slips and the revs go through the roof then it's time for clutches and steels
