1 - 4 of 4 Posts
Hey guys I just had my completely built 48re input shaft shatter on me. So I am putting in my other 48re built trans in. The problem is that the trans I'm putting in is the original trans out of the truck. but I'm the second owner of the truck, and I need the bolts for Transmission Shift Controller Throttle Valve Actuator, and have no idea what size they are, if anyone can help that would be great.
Fastest Welder in Texas
2004 Ram 3500... 6.4 Cummins with some stuff.
So then, the trans you are taking out would have the TV cable, and the one you are installing has the actuator?
No they both had the shift motor, just the one had aftermarket bracket, and the one I'm stalling has the bolt holes casted in the casing, I just don't have the bolts or know the bolt sizes
Maybe Cerb or one of the boys can measure one for you. I'm guessing m10x40 or 50
1 - 4 of 4 Posts
