anyone got any info i'm wondering about doing the same kinds of things any help out there:confused013:
The only warning flag on yours are the tires. Too much bigger tires is hard on the direct and forward clutch packs on a stock trans. You have to pull them anyway to do the input so rebuild them. Its a good bet the rest of the trans is good. The only other thing you need to take into account is the rear servo. They tend to wear and jam under higher pressures and really need a replacement to insure all the problem areas are addressed. Once you get there, freshening the whole trans is not that much more if you can swing it.I plan on running a smarty,intake, and exhuast in my truck eventually but id like to upgrade the tranny and get some gauges first. I was thinking of putting a t/c, billet input shaft and a shift kit. The truck already has 82000 mies on it and i was wondering if i should go ahead and do a heavy duty overhaul while i have it out. Anything im missing or sugesstions on what i should do? Thanks
You on the other hand, need a complete rebuild. :hehe:anyone got any info i'm wondering about doing the same kinds of things any help out there:confused013:
A valve body in my opinion might be better just because it increases the pressures in the VB which provides firmer shifts for your clutches which will not allot them to slip.I plan on running a smarty,intake, and exhuast in my truck eventually but id like to upgrade the tranny and get some gauges first. I was thinking of putting a t/c, billet input shaft and a shift kit. The truck already has 82000 mies on it and i was wondering if i should go ahead and do a heavy duty overhaul while i have it out. Anything im missing or sugesstions on what i should do? Thanks
A shift kit does the same thing. Most custom VB's are nothing but a stock VB with a shift kit and maybe a few mods the builder likes.A valve body in my opinion might be better just because it increases the pressures in the VB which provides firmer shifts for your clutches which will not allot them to slip.
