1 - 3 of 3 Posts
i have a 1995 with a 47RH automatic tranny. i want to do a swap for a NV4500. what all would be needed and would it be worth the money to swap to a 5 speed or should i build up the automatic?:peelout
I did the swap -- it was very worth it for me. It takes a lot to build an auto tranny to hold moderate power. An NV4500 with 5th gear fix and a southbend clutch will give you all you need for a daily driver.
I can come up with a complete parts list if you want, but I do not have exact part numbers anymore.
I did the swap on a first gen was well worth it to me. Here is a web site that sells kits to do the swap. Not saying to buy from them or not would be cheaper if you could get the parts on your own. Although there site has some good info as well as a list of whats needed. Good luck if you decide to do the swap let me know am looking for a 47rh for a cummins rock crawler.
Dodge 5.9 Diesel 88-03 auto trans rplmt
1 - 3 of 3 Posts
