Here's instructions for lockup switch:
Click> http://www.cumminsforum.com/forum/9...anual-torque-convertor-lock-up-switch-nc.html
If I had to guess, I would say no fuel plate is what "smoked" overdrive. The TPS only tells the PCM when to engage OD and lockup. Playing with fuel takes out converter and OD. If you are going to keep the fuel plate out, you will HAVE to upgrade or replace valve body and install a good torque converter. Three common companies on here are Goerend, DTT and Suncoast. All three carry good converters and DTT also carries a DIY custom made valve body kit. If you plan on locked shifts with your new switch, then you will also HAVE to at least install a billet input shaft. Also, in order for trans to work properly, you will need to replace the TPS and get it properly adjusted. Unforturnately many have found you can very inexpensively play with fuel, but the trans will cost you some money to make it hold up.
