Banned
Let's say the PCM is fried for some reason.
EMP.
Electrical system failure.
I get a little too drunk and decide to drive into a lake.
Whatever reason.
Will the 47RE do ANYTHING without a functioning PCM? Even just running in the first three speeds without Overdrive or Torque Converter Clutch lockup?
EMP.
Whatever reason.
only a 12 valve will truely be an EMP proof truck :thumbsup:
I've done the whole drunk/huge mudhole with a 4l60E & oulda served about 65 strawberry shakes....
Manual valve body is the only way a 47RE will function in any drivable manner without the PCM.
So, how was the water?
Ed
Reactions: dozer12216
You may have 1st gear and reverse. You might try taking cover off pcm and dry out. I beleive it is potteded with epoxy. the connector pins are the first issue to work with.
A conversion to 47RH is very difficult and would require intinimate internal trans workings knowledge and excess parts as governor is different.
