anybody ever dropped their transmission out in the street/garage/etc without a vehicle lift cuz they didn't have the vehicle lift? if ya did how was it:thumbsup
I wanna go fast...
I used a four wheeler lift and two 6x6's and a strap to secure it. Worked out great!
coolness....how did you go about taking the transfer case and the crossmember out?:thumbsup:thumbsup
i did mine onthe garage floor w/ a floorjack totally by myself cuz the wife was preggy. did the t case seperate. the crossmember is a . sledgehammer and a couple 4x4s cuz youll pound thru em beatin that cm in and out. the trans isnt too awful heavy but hard to alighn the tcaase back when its goin in cuz its on an angle. also turnin the motr is best done witha big screwdriver on the flywheel teeth. from the btm so ya dont hafta keep goin up top to turn it offa the pulleys. i think the cooler lines were the worst part probly
TECH SPECIALIST
I did a complete auto to manual swap outside on the grass with floor jacks.
No trans jack, no auto lift, no nothin'.:thud:
Just start by unbolting the transfer case and remove it first. It's not very heavy. Then take a big hammer and knock the crossmember out. Then just unhook the trans connections and secure your jack underneath it. Unbolt it, then slide it out. :thumbsup
that doesnt sound too bad. how easy is it to install a new converter and valve body. is the valve body best done on a bench or up in the truck ? any tips from you guys ?
Quite a few parts in a valve body. Are you tearing it down or just replacing it? If tearing it down you can pull just the valve body out fairly easily ('cept for the dang park rod C clip) and take it to a bench or better place to work on it. Push the spring coils together from under each plate if you pull it all the way down all at once. A couple springs are very similar but need to go back in the same place. Make sure you know where/which way each valve goes back in. Keep it clean and use lint free rags.
ordered a converter vb combo from gus. converter is here just awaiting the vb. he says it has instructions, but want to hear how you guys go about it.
