will a 47re trans out of a 97 work in my 2000??? i found a good deal on one and didnt want to jump on it till i found out. thanks tom
well that depends if it is a rh or an re. the rh is hydrolic controled the re is run by the computer. i think that the switched to the re in 98 but im not 100% shure.
The switch to RE was in '96. It SHOULD interchange but you will have to put your '97 valve body internal wiring harness and governor pressure sensor on the '00. ('00 wiring harness shown)
Naw! NAW, you got that wrong. Put your 2000 electronics in the 97 to make it work correctlly on the 2000 truck. Make sure the output shaft splines are the same....
