1 - 4 of 4 Posts
my intermediate band is on its way out....does any one know if it can be replaced "in frame"...and if so will the oem band work or does it have to be a special design to be installed with the transmission in the truck.....thanks
Banned
hmmmm....... are you talking about the 2nd gear band that can be adjusted from the side of the transmission via a lock screw thing?
As long as you pull the motor first. As I remember you gotta pull the front input/drum assembly to fit the band in. This is the band that wears out, the other one will last a life time. Put a performance band back in, at min. the OEM Hemi band.
Banned
HAHAHA.......yea, pull the motor, leave the transmission in......... Sounds like ya need to just yank out the whole transmission
1 - 4 of 4 Posts
