I'm having problems with the trans I've just rebuilt on my 98. I got it all put back together and taking it for a test drive it slips between 2nd & 3rd and 3rd & OD with more than medium throttle applied. This only happens with OD engaged, with OD locked out it doesn't slip.
All the pressures are up to spec with what the service manual says they should be. I've also eliminated the valve-body as the problem(bought a DTT valve-body thinking that was the problem) is there anything else I can eliminate before I tear out the trans again? Or before the truck ends up at the bottom of Lake Mead.
TIA,
Corey
TIA,
Corey
