My question is, can you put a valve body from a 47rh into a 47re trans to convert it?
But if you swapped the overdrive section and valve body it should work? I was needing to swap the OD section anyway to convert to 4x4.No you cant will not work the governor on the 47re is on the valve body the governor on the 47rh is in the overdrive section
Awesome thanks for the info!!!!! The search continues for a 4x4 47rh then.... I may end up having to buy a parts truck.No sorry it still wont work the intermedit shft is different also the 47rh is longer than the 47re is.
I have read that an overdrive section from a first gen a518 (46th) will work just fine on the 47rh (to convert 2x4-4x4) since you seem to know what you are talking about do you have any input? I have a line on a 95 2x4 that I could steal the trans and then part out.Yeah there hard to find they were only in the 94-95 trucks. I seen one on craigslist the other day I my area but ur far away from me
