Kind of an odd problem here. Truck has 68k on it, I put a trans go in 1500 miles ago, tightened the front band to spec and it shifted nice and firm thru all the gears.
Over the past two days tho, it started hunting between 1st and 2nd at very light throttle. At normal throttle, it shifts 2nd nice and firm, then 3rd, and 4th. It will hold at WOT with the Edge Juice on 5, no slipping, slidding, or hunting. The problem is just at very light throttle with 1st to 2nd gear. When it starts to hunt, I can step on it a bit harder and it will either stay in 1st a bit longer then shift firm into 2nd, or push right into second depending on speed.
I'm thinking its a speed or pressure sensor problem. When we did the VB we cleaned up all the sensors but did not replace them.
Thoughts? I would like to fix this before the cold sets in. I've read there are updated pressure sensors??
BTW, the truck is a 99 4wd.
Thanks guys
Nick
Thanks guys
Nick
