Any other way to eliminate it other than having to purchase a smarty? Is it possible to get someone with some type of scan tool to kill it? Everything I've read about that event seems like it's just not good:confused013:
Isn't the third event the dreaded "cylinder wash" that they claim puts fuel in the oil ?There's absolutely nothing wrong with the 3rd event, doesn't hurt a thing.
No, that event is only activating when cylinder pressures and temps are high. There is no chance, given everything is operating correctly, that that will cause fuel in the oil. It does cause more soot loading but not fuel.Isn't the third event the dreaded "cylinder wash" that they claim puts fuel in the oil ?
I've seen quite a few oil analysis reports from 3rd gen dodges (including my own) and don't recall seeing many that had fuel in the oil.Isn't the third event the dreaded "cylinder wash" that they claim puts fuel in the oil ?
I have good oil samples all the time, never positive for fuel. There are those on this forum that claim their fuel in oil problem stems from the late injection.I've seen quite a few oil analysis reports from 3rd gen dodges (including my own) and don't recall seeing many that had fuel in the oil.
That said, it does stand to reason that a late injection event could do that depending on how often it actually activates.
If I thought it would increase injector life by a decent amount I would get a smarty just to shut that event off. I rarely see above 2k rpm though, so if it is really only at high rpm that it activates mine doesn't see the third event very often (if at all).
They may say that. But it is 100 percent untrueI have good oil samples all the time, never positive for fuel. There are those on this forum that claim their fuel in oil problem stems from the late injection.
