1 - 13 of 13 Posts
3rd gen 20" wheels what size tire reverse leveled truck. Looking at the 285-55 or 305-55. Want to keep an E rated tire in case I do light towing on rare occasion. Pics would be great. I do not want to raise the front!
Yes I have done a lot of research prior to this however haven't found a lot guys running stock height with 20s in a 285 or 305. Hate to go any skinnier than the 285. Thinking about a -12 offset.
I have 20x10 -12 offset with 305/55r20 toyo at2 but I don't know how to post pictures yet but I also removed all the spacers out of the rear. Look in the low and wide stance forum in show time. I plan on removing the overload and getting 305/50 proxes for street use if you have any questions let me know
Learning Process
Just a little lower then you are talking but my 20x9 Fuel wheels do great with NITTO 420's and 305-50-20 At's:thumbsup:
As you can see beside my Mega-Cab with 35-12/50-20's NITTO AT's
Reactions: fatgraderman
what offset are your fuels and would a 305/55/20 be close to what you have? also any kind of rub?
I'm running 20x10 XD Brigades with -24 offset. Got 305x55x20 Cooper Zeons on it. No rub at all.Factory suspension.
Somewhat the same setup im after. But 20x10 -25 worx's wheels on 35x12.50x20 cooper stt tires. Everyone local says I won't be able to turn even with a leveling kit. This shows me its defiantly do able
Well a 305/55/20 is a 33x12.50 so with that I think there's a chance but a 35 I wouldn't think would even be close. I'm wondering if having that aftermarket bumper is why you're not rubbing
That may be possible. It gets close to the fender by the door when turning to where I can barely squeeze my hand between it so with a factory bumper it may hit.
Guess I should post these since i got it done before scheid
how did you get the rear of your truck so low? no overload springs?
What size tire did you end up going with, and what offset wheel?
Looks good.
I have a 2008 dodge 2500 6.7 cummins. Just bought 20x12 rims lowered in rear end on Springs... my questions is will toyo proxes s/t 305/50/20 120v all season be ok to run on my truck. No hauling or anything.
1 - 13 of 13 Posts
