So as many may know my fuel line had ruptured and so many of you guys were awesome.
So I wanted to post up what I did.
First know what line is out, what i did was turn the motor on and found which line was spouting fuel.
Like this: be sure to protect your eyes
Then take 10mm socket to loosen the bracken on the the block.
Be sure there is no debris around here.
Then take you new line and a line to make the fit correct
Then tighten down
You really should use a line wrench an I believe that it was a 18mm.
After you have tighten then inspect for leaks.
And the your done.:thumbsup:
