1 - 12 of 12 Posts
Got a friend with stock 06 coils and 3 inch coil spacers. I want to go back to closer to stock height. Will his coil springs work on my 97 and his spacers?
Discussion Starter · #2 ·
Come on. Surely someone has to know
Yes they will fit, however your ride will suck. The 3rd gen coils have a higher spring rate so it will be a rough ride.
Are they just rough on our trucks or is it the same ride quality you would experience in a 3rd gen?
The 3rd gen is heavier so the spring rate is higher. If you put them in a lighter truck the spring rate is too high. I would probably compare it to driving a 1st gen as far as bone jarring ride.
You could try locating some PowerWagon springs...or give one of the big guys a call... Thuren or Carli. They will get you set up for what you need.
Well I can get the springs and spacer from my buddy for like 100 bucks.
Gotcha. You could always just give them a go and if you don't like them just resell them
That's actually a good idea...
Or just use the spacer on your coils.
Never mind saw that you have superlift coils on it now.
Discussion Starter · #10 ·
I have 6" coils. I want to go smaller. Not bigger
Discussion Starter · #12 ·
No they are from a cummins
1 - 12 of 12 Posts
