1 - 4 of 4 Posts
Ive got a 02 dodge with a 2in L-kit! It still sits down it the front about 1in! So I bought a 3in! am i gonna need trailing arms and all that mess?? Any help is great!! thanks!!
Whats up man? I don't think you will have to have control arms but it would help. The only thing I would say you might need is a track bar bracket.:thumbsup
Should have longer Lower Control Arms with that much lift. It helps correct the pinion angle of the front end. Also need a adjustable track bar. Personally, I'd just throw a few hundred pounds in the bed. That'll level it out and help it ride a little better.
I went 3 1/2 "s and had no problems until I put on a set of fatter tires then I went to longer control arms. 1.to eliminate the tire rubbing on the back wheel well. 2.to equal out the open wheel well space from the front of the tire to the rear of the tire.3.I went a full 1" longer on the arms just for the challenge which you would not need 1", a 1/2" longer for you would probably work.
1 - 4 of 4 Posts
