I have a stock 2007. I was wondering if i can fit 37x12.50. On my non lifted 2500? I have a deal on a set of procomp extremw mt2's. With 5k on them for $400 mounted and balanced . If so anyone have any pics
how do longer control arms prevent rubbing the back of the wheel well? :confused013:Longer, higher clearance control arms.
17" x 8" -4 offset 4.25 BSMWheel offset also plays a huge part in tire rub, If your rubbing the back of the fender with 33's then you running a low offset wheel.
How much does that rotate the axle?It pushes the axle forward away from the fender.
But we are talking about STOCK to begin with, in this entire threadIf the control arms are proper length the axle should not really rotate,caster should still be within spec
The longer control arms re-center the axle in the wheel wheel putting your springs closer to there stock position when lifting/leveling
Depending on the amount of lift the slip joint takes up the difference in length on the front driveshaft, the higher you go lifts will often include a driveshaft spacer or have you clock the t case I believe. Some choose to lengthen their driveshafts to reduce U joint angle
Lifting/leveling with stock control arms and track bar pulls the axle backwards and to the drivers side of the truck
