custom user title
Hey guys I have 37x12.5 tires on a 17x9 rim I have a long arm lift that has a slight bend in the LCA for tire clearance
The tire rubs the control arm and it can be super frustrating when backing in trailers, off-roading or even pulling into a parking spot straight...
I honestly am unsure how to get the wheel to stick out more aside from using a wheel spacer, is there a certain amount of back spacing you need to run? Or is the rubbing part of putting part tires on a truck?
What are you guys running for tires and rims? Any rubbing?
Local tire shop says to put smaller tires on, and everyone else I ask say just to deal with not being able to turn full lock
Agree with Rhino, 4.5" backspacing is the sweet spot with long arms I've found as well.
