1 - 12 of 12 Posts
Ok, well here is the deal. When I first got my Holley Black pump it said 6PSI, stretched the spring and was able to get 10psi idle and 8 at WOT. I just said screw it, the guage is probably off. Well just today I loaded the Comp3 tune(its great by the way) and now it says 37-45PSI(it bounces around a little). So what is the deal??? Am I really getting that much???
Thanks,
Chris
Rescue Tower
There is no way we can tell over the internet... You need to verify with a second gauge...
I dont think you can get that much from a black. maybe 21 tops, but i have heard of weirds things before
No, I was not running the new transducer(although I am not sure what that is). I am thinking of putting the valve stem back in the bleeder valve and seeing what a tire guage reads. Afterall, pounds per square inch are pounds per square inch, right?
Tech Specialist
It's impossible for a black to push that pressure even if the bypass is completely blocked off.
I am assuming you are running the old, big sending unit, that has 1 wire connected to it?
If that is the case, the new software does not work with that sending unit, only the transducer.
If that is the case I need to make you a different software update. According to our records we have recieved all the old sending units?? That is why the new update does not support it.
Well you got one more coming yet. :thumbsup:
It should be there soon hopefully by the end of the week for the upgrade.
Discussion Starter #10
I am running a 0-100psi fuel pressure sending unit, I will have to look and see what brand it is, but there are two wires coming from it. I believe it was $50...
I bought the unit separate from Quadzilla yet used the original harness to hook it up.
Western WA President
mechanical fuel pressure gauge is the way to go...I don't trust electronic gauges. small amount of electrical noise or moisture on the wires can throw the readings off.
Discussion Starter #12
I agree with that...I am probaby going to get mechanical FP as well as boost and drive pressure guages..
1 - 12 of 12 Posts
