1 - 19 of 19 Posts
just picked up my truck..man this clutch is saaweeet! feels like a real truck now..its stiff but not that extreme..im getting ready to go out and rip around a little more i'll update as i get more miles on :woot:
Keep us updated. I just ordered one and will be getting it in this week, well maybe I'm glad to here you like it.
smoked..i see your from york, i'm from stewartstown, where abouts in york are you from? maybe we could meet up sometime..the clutch is awesome..taking all of my abuse so far, need more cash also..it def grabs when you let it out, a little slower on shifts but still shifts nice and smooth..i was out the other night tearing up powerjokes :rof..i love it! its def worth it!
Tech Specialist
I have one sitting at the shop ... going in tomorrow.
Peter's clutches are impossible to beat! :thumbsup
Shiftin Fool
heres one of peters clutches at work!! with only a 3250 pressure plate. believe me they take a ton of abuse.
YouTube - my 12.92 pass.
smoked..i see your from york, i'm from stewartstown, where abouts in york are you from? maybe we could meet up sometime..the clutch is awesome..taking all of my abuse so far, need more cash also..it def grabs when you let it out, a little slower on shifts but still shifts nice and smooth..i was out the other night tearing up powerjokes ..i love it! its def worth it!
I'm reall from Red Lion I just put york since if you not from the area you won't know where Red Lion is. My cousin lives in Glen Rock you might now him. He has a 04 white quad cab. (Ben). Anyway If you are going to the Buck for the truck pulls in June maybe we can run over together. Once I get my clutch in I do plain on pulling over there. I'm thinking bout draging if I can find a short shifter kit til then.
Do you guys with South Bend DD clutches have some noise when the truck is in neutral, and the clutch pedal is released? I just put mine in last night, and I seem to have a fair amount of chatter at idle with the pedal released.
Shiftin Fool
a fluid damper helps a ton. quiet that down. i barely have any noise at idle in nuetral. :thumbsup
I'm pretty sure that's just the throw out bearing rattlin around... completely normal my man
Whats the fluid damper do? I hate all that rattlin.
Shiftin Fool
smoothes out engine vibrations. it will lessen the noise big time!!!
I have no noise at idle with the clutch released.
So the fluid damper takes the place of the dual mass flywheel then.
Shiftin Fool
It's actually the floater plate....
If it was the throw out bearing, you'd need to replace the bearing.
Merrick
1 - 19 of 19 Posts
