Today I got underneath my 3500 DRW 4x4 and did some observations of the new chassis under this truck. I must say I was very impressed with how stout and heavy all the front end equipment is, The chassis design is awesome and looks like a tank frame. The oil pan, transmission pan is fully protected with steel skid plates. I saw all the inspection marks noted that it was checked off. I see now why the truck is so quiet. It has sound deadening material and heat shields under the cab floor. There was a little room between the DEF tank and fuel tank where a 35 gal tank might fit in place of the 32 currently installed. The rear axle and leafs are massive. no wonder it rides like a truck. All in all I think Ram did a good job with the new chassis design. arty018:
I had to hold out for a 14 2500 to get the beefed up hardware. Finally looks as beefy as it should be under trucks this capable. Drives outstanding too, no more steering wheel shake when going over expansion joints at speed in a turn. Nice and tight. Very impressed so far. The coil spring rear on the 2500's seems to be much less jumpy on broken roads vs a leaf sprung truck.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Cummins Diesel Forum
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
