1 - 16 of 16 Posts
I have herd of a guy around home putting 308 gears in his 94 or 95 2wd truck and is getting around 26- 28 mpg. Is this possible to do it in my truck (see sig). If so could i still pull my camper its a 34 footer and weight about 9500 lbs. If i could get it around 1400 RPM's at 70 MPH, it would be great.
Discussion Starter · #2 ·
bump..........
im sure it could be down and since you have the six speed you should have no trouble moving your trailer
Where would be the best place to find some gears?
For the AAM 11.5" the 3.42 is it. Add 285/75/17 with the 3.42 will get you to 3.17.
Personally I wouldn't try towing that low of a rpm. That's lugging and will increase fuel consumption. Best to keep the rpms around 1800-2000 for power and efficiency.
MikeyB
what gears do you have now? i switched from 4.10 to 3.73 and saw a 4-5mpg improvement to about 18mpg. with fuel the way it is now:CRY: i should have gone higher
I saw someone on Ebay selling a 3:08 rear axle for a first generation so they must be available Check with JT parts and accessories . they are a vendor here on the forum they got my 3:42s for me. They could probably tell you if they are available . 509-888-2953
actually the first gen's have 3:07's not 3:08's
Discussion Starter · #10 ·
I HAVE 3:73'S NOW
More gear ratio rambling
As far as I know (that ain't too far) the American Axle eleven and a half type axle now has three options of 41/10, 41/11, and 41/12 for ring and pinion. You do the math and round off and you get the 4.10, 3.73, and 3.42 that people usually quote. I just went from 3.73 to 3.42 in a 2007 2wd with a 6 speed and a 5.9 engine; not sure if it is going to save a bunch of fuel, but it sure is nice not looking for that 7th gear on the highway anymore.:thumbsup
Any before/after mpg results?
1 - 16 of 16 Posts
