What kind of pump you running? OK, Duh.....holley blue, I see it now. I think I read some where if you increase flow it will decrease pressure, I think by going to a 1/2 hose or something is where you would increase the flow, unless you have done that, big line kit is what I mean. Most likely I'm not of much help, I googled it and there is some info out there.
On another site, don't know if I can post it here, but another guy had the same problem and then someone mentioned a bypass he bought from Richard at Glacier diesel power that comes with shims that you can set fuel pressure where you want. Said his was at 26psi and after the bypass its right at 13psi. Here's a link to glacier they posted,
Glacier Diesel Power - Product Detail. He said they sell the bypass seperate, tell Richard the problem and so on. Good luck...hope this helped.
