Thanks for letting me know. As for the speedo, all of the trucks just have a VSS (speed sensor) on the rear differential. It just measures the speed of the axle itself, so changing the gears doesn’t require any programming. I bought the set to swap from 3.73s since I have an early model G56, to get a better cruising rpm, but now I am installing a gear splitter instead. In my opinion 3.42s would work exceptionally well with manual trans, since their ratios are almost always higher numerically (auto ~.69, manual ~.74), and these engines have plenty of low end torque… Hopefully that makes sense it’s tricky to explain and I’m sure I’m not doing the best!Classified ads require a price, just FYI. Might catch a nasty-gram from the mods.
However, for those of us who DD and don’t tow as much as the truck is intended to (me included), how did you program the speedo and odometer to read correctly with the 3.42s?
How much of a difference does it make in driving? Did ya add a metric poo-ton more power or just deal with it being sluggish? Any effect on the trans being able to hold the torque since it’s ramping up into load faster?
