Long story short, I bought a 2wd trans and need a 4wd trans. The output shaft will obviously not fit into the t-case. I misunderstood and thought you could use the transmissions interchangeably by swapping the rear section of the housings . Is there any other option to making it work other than getting a 4wd trans??
Tried to have a driveshaft built and make the truck 2wd temporarily but the driveshaft would have to be too long for anyone to safely build, and I don't want to get into fabbing a crossmember for a 2-piece shaft.
Also, I doubt I can return the trans b/c it came from a private seller on the other side of the U.S.A.
