We also find some cracked pistons.
Trans/T-case out and engine coming out.
And now we find 2 cracked/broke mains on the block.
I jumped the gun on the pistons and bought a set of .020 over coated pistons for this block since it was already .020 over and the cylinders looked fine. After I bought them is when I discovered the block is junk, so they are for sale in the 2nd gen section. I decided on using a brand new short block. I also got a good head from a buddy of mine. I pulled the pistons from the short block and took them and the head over to C-Tech Performance in Grand Rapids, Mi. They are going to cut valve relief in the pistons and firering and port the head. I thought of cutting off the intake shelf but I just can't swallow $1300 for an intake. Once they get done with it I am sending the pistons and head to SwainTech to have the pistons coated and the head and valve faces coated also.
I got a modified Gorilla Girdle and studs from Industrial Injection to stiffen up the bottom end. The crank is going to get sent out for balance. I think I'm going to use my old rods since they are the England made rods. The rods that came in the short block are 5 from Mexico and 1 from Brazil. They way I understand it the England rods are supposed to be better. They are going to get magnafluxed for cracks and checked to make sure they are still straight.
I am having a hard time getting a hold of Hamilton Cams to talk to them to find out which cam to go with. I'm looking at the 188/220 and new tappets.
I want to build me a sleeper truck. Retain as much of the stock look that I can, even under the hood. There is gonna be a lot of powdercoat under there too. This is my daily driver. It is not going to turn out to be a Saturday Mecum or Barrett Jackson auction truck but hopefully it is good enough for a Thursday or Friday nite show.
