1 - 3 of 3 Posts
Just picked up a 95 2wd and I wanna lift it up. So far looks like I'll be doing 2.5" spacer in front and 1.5" block in back. Is that the biggest I can safely go(will not do body lift). Do they make a 3" spacer kit?
Discussion Starter #2
ok i see i probly should have done a little searching first, i see this topic has been kind of beatin:bdh:
so i'd like to refraise my question:S:
so you have the 2.5" daystar kit, then the fat bob 2" kit, and various ebay kits including ones that say 3".
which ones actually lift those amounts, cause i noticed on some they say that the actual amount of lift can be less. like they are advertising the actual lenght of the spacer not how much it lifts the truck when its installed. so was wondering what kit you guys have out there and how much it actually lifted your truck. thanks.
Be careful with anything over 2"..... The 2nd gen 2wd control will be topped out on the coil buckets on the frame. You really need a tubular style arm for 2.5" +
1 - 3 of 3 Posts
