1 - 2 of 2 Posts
finally did some more research and got the rest of the 2nd generation 12v specs, so hope now you know more bout your 96-98 12v cummins engine :drool2:
Power (SAE net)
215 bhp @ 2600 rpm - 49 state manual
180 bhp @ 2500 rpm - all auto. trans
180 bhp @ 2500 rpm - CA man. trans
Torque (SAE net)
440 lb-ft @ 1600 rpm - 49 state manual
420 lb-ft @ 1500 rpm - all auto. trans
420 lb-ft @ 1500 rpm - CA man. trans
Compression Ratio: 17.5:1
Engine: 5.9-Liter, OHV, Diesel Six-Cylinder
Type & Description: Six cylinder, in line, liquid cooled, turbocharged, intercooled
Displacement: 359 cu. in. (5.9 L)
Bore x Stroke: 4.02 x 4.72 (102.1 x 119.9)
Valve System: OHV, 12 valves, solid sliding tappet lifter/followers
Valve Adjustment (engine cold)
Intake = 0.010" Exhaust = 0.020"
Adjustment interval - 24,000 miles
Fuel Injection: High-pressure direct injection, mechanical
Fuel Pressure: 18-24 psi at idle, 28-36 at 2000 rpm with no load.
Construction: Cast iron block & head
Fuel Requirement: Diesel #1 or #2
Oil Capacity: 11 qt. (10.4 L) with filter
Oil Flow Rate: 20 GPM
Coolant Capacity: 24 qt. (22.7 L)
Emission Controls: Engine modifications, oxidation catalyst (after 1/1/94)
Alternator: 136 A
Battery: Maintenance-free, dual 750 CCA
94-98 Valve Specs
seat angle(degree) = 30
face angle(degree) = 45
spring test pressure([email protected]) = [email protected]
spring installed height(in.) = 2.36
stem-to-guide clearance(in)
intake = 0.002-
exhaust = 0.006
stem diameter(in.)
intake = 0.313
0.314
exhaust = 0.313
0.314
Ram Diesel Turbocharger Specifications
1996-1988 engine:160, 175, 180 HP max boost:15-18 psi turbocharger: Holset HX35W 12 sq cm turbine housing
1996-1998 engine: 215HP max boost: 21-23 psi turbocharger: Holset HX35W 12 sq cm turbine housing
Pyro Probe Location l Max Temp At Rated Power l
ehaust manifold = 1250 Degrees F
exhaust elbow = 950 Degrees F
1 - 2 of 2 Posts
