1 - 1 of 1 Posts
so i have no speedo and i start in 2nd gear. i found that the front drive shaft wore thru the wiring loom of the output speed sensor.
i fixed the wires and still nothing
i figured i shorted out the sensor so i replaced it....still no go. i dont know what to do any more i have a list of codes
12-Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections.
45-Transmission OD solenoid circuit failure. Open or short in the transmission overdrive solenoid circuit.
37-Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input.
44-An open or short in the engine coolant temperature sensor circuit or a problem in the PCM's battery temperature circuit.
55-End of message code.
im stumped here, please help!
1 - 1 of 1 Posts
