1 - 4 of 4 Posts
My truck will not shift from first to second unless i wail on in to get it moveing then cut out and start again feathering it then it will shift did a fluid swap and made it worse
is there a possibility for me to just replace the bad gears or do i need a full trans
and for a new trans who what kind from where and roughly how much???:banging::$::$::$:
Rescue Tower
Did you adjust the bands while you did the fluid?
yea i ajusted the bands when i made the swap of fluids
How did you do the adjustment? If its wrong your going to have all kinds of issues, also check that the kick down cable and lever are still hooked up. I've seen the lever pop off the shaft,
1 - 4 of 4 Posts
