1 - 14 of 14 Posts
Im wondering what can be stacked with the smarty. On the web site it says you can stack it with fueling boxs. Thus would be my blue chip, it also states if you run the setting with no timing you can run a timming box stacked as well. Anyone who may be able to help would be great...
I was told that you run the edge juice with the smarty if you run the smarty on even numbers...
I would like to know more about it cause i was intrested in doing the same..
smarty and edge works, and works well. Also i belive that you can stack with a TS box too....not 100% sure
smarty and tst! Drew at coal train could hook you up, he had that stack on his 01 dually and holy crap!
Is it worth it to stack the smarty and can you do it wth the attitude too?
Sorry to hi-jack. I know most don't the predator, I have had good luck with it. Would the Smarty stack well with it?
Smarty will stack with everything except other downloaders... it has timing and no timing settings just for that purpose.
the smarty and edge are amazing together..the smarty brings out the best f the edge...I had been told it is the best stack for our trucks and I can honestly say I believe that to be true
TSTand Smarty...especially with TNT...WOW!:thumbsup
one of my friends has an 05 with a edge and smarty, its a mean stack on that truck... i also have another with an adrenaline and smarty on a 2001 and that truck rips as well. id say that something + smarty = awesome power.
1 - 14 of 14 Posts
