1 - 20 of 54 Posts
Ok as you can see in my sig i drive a powerjoke BUT its up for sale so i can get a cummins. Ive decided to go with a 24v more than likely so i was wonderin what year i would want for the best hold up when running 450 500hp. It will be a 6 speed. Im just tryin to get as much research on them so i get the right year and stuff the first time. Thanks
Be Aware of the 53 block, they're found in dodge trucks a up untill '01 the 53 engine block is prone to crack between cyl. 5 and 6 on the pass. side of the block just below the freeze plugs. They're aren't very many of these blocks out there, and not all of them crack, I've heard of some pretty high HP trucks with these blocks and they're not having any problems. I've also known stock engines to crack, mine is cracked as we speak, with the mods in my sig.
I'll do some diggin' and tyr to find some more info for ya!
Well unlike the powerstroke, all the cummins engines will hold 450-500hp easy, it just depends what you like more and what you want to buy to get there
Cummins Fanatic
6 speed is only available on an 01 or 02. 98.5-00 you can get a 5 speed.:thumbsup
a 5 spd is a lot cheaper to rebuild if something goes wrong because the 6 spd in these trucks arent manufactured anymore
Banned
when you find a truck just check it for the 53. mines a 53 no crack. i dont know about the 6 speeds but id say if they dont make it any more dont buy it my .02 i dont thank you really need a 6 speed its just nice to have:thumbsup
Banned
i thank the HOs are only like 10 or 15 hp more a comp box will give you more then that:thumbsup cant anser if there 5 speed
Props for switching over to the Cummins! You won't be disappointed at all! You may want to change your name after you get your truck too. Just a suggestion. Powerstrokes aren't looked at very kindly (with good reason).:thumbsup
from what Ive heard there is really no advantage of a 6spd over a 5 spd, the overdrive ratio is the same, the 6spd just has a extra gear in there somwhere so there not as big of a jump in ratios.
Yes the 53 blocks crack more often then other blocks do but all in all they don't crack that often, and if it cracks most of the time the crack can be fixed.
Banned
pics pics pics and is it a 53 block?
Cummins Fanatic
Ok well i found an 01 5speed ext. cab shot box with 124,000 miles. They replaced the injection pump and lift pump, steering bar for $13000 what do you guys think about that.
Sounds like a good deal to me! Although I didn't see what it looks like. I have found that it is kinda hard to come across 5 and 6 speeds. I think I'd buy it if its in decent shape
1 - 20 of 54 Posts
