Steve, what is your trucks "ideal" IAT?The warmer the air, the less aero resistance you will get. How much that adds to mpg, idnk. Warmer intake air temps definitely = better mpgs... Just be aware of that fan clutch limit.
In general, the higher the ambient air temp is the less time it will take to get the truck heat soaked for the best mpgs. Meaning, differentials, bearings, transmission etc. all will give a lesser amount of resistance hot vs cold
I observed on my last 1300 mile trip differences in LOM mileage. In the morning mpg were less than in the heat of the day. Also, when I got up north, that evening temps dropped from 80s to 60s. LOM dropped in relation to IAT. Truck was heat soaked.
I looked at IAT changes as ambient went up and down vs. LOM reading. Naturally, IATs followed ambient temp. IAT was from 5 to 10 degrees F above ambient. Both of ambient and IAT sensors have been replace in the last 12 months.
Humid air is less dense than dryer air. Counter intuitive but the numbers don't lie.
Density of air
I race where a thousands of a second is the difference in winning or loosing. We look at all the variables. Other AIR variables that impact MPG/HP, temp, elevation, barometric pressure. Some folks have weather stations in their trailers to get track data vs. a weather station. It's that important.
I thought since these are compression combustion engines, there is an ideal charge temperature that produces the best MPG. To really know, a test should be run with constant elevation and barometric pressure. My trip to IL didn't take into consideration these two important variables.
My starting point elevation 643' and final destination 670'. Next trip I'll note elevation and B pressure each time I stop. I might have to get an assistant to enter the data as we drive!!
Yet, when I was driving to my final destination in IL, dropped off my load and started back south 50 miles in the evening, MPG dropped. Ambient dropped about 15 degrees. The next morning, in the 60s, truck lost MPG while it heat soaked. After it heat soaked MPG stayed about the same as that evening until later in the day. As temps went up, MPG went up.
Has anyone else notice MPG changes related to IAT or ambient temp?
