Great numbers!!
At exact 1,300-miles:
— 56.5-mph reflects reality pretty well (23-hours).
— 62-mph would have been the Average for doing 70 (if all Interstate; so 21-hrs)
— The “time savings” would have been under three hours as traffic volume interference increases the gap between Set Speed and Average Speed. It’s not just the aero penalty either:
A). Pull Out to Pass Penalty
B). Brake for Slower Penalty
C). Steering Penalty
D). RPM Penalty
— Steer more, change throttle opening more, use brakes more. Each adds to the aero penalty. And the above 1,900-rpm factor would also be at work. (Pull out to Pass is mental/emotional energy; gets one run down earlier in the day).
Two hour change is likelier. Over three is unlikely.
1,300-miles in (2) days is a fair truck driver test (seat cushion, hmmm) as it’s stretching the limits for the energy & awareness necessary to keep safe practice at highest level through a long day.
Perspective: we all do well to the 400-mile mark given adequate preparation. Past that is where White Line Fever sets in and our Reaction Time & Distance are worse. Everyone gets sloppy. (No exceptions).
MPG goes down during the day where all else is the same.
Q: How does one counter this?
A: Leaving earlier to spend less time in higher volume traffic as being alone is success marker for safe operation plus highest MPG. Truck and operator expend less energy.
— If in a big truck given your 57-mph EH, “travel time” would be dead-on 13-hours with a 50-MPH Dispatch Estimate (0230 Departure) to have bought fuel at 1730.
1). Departure Time is crucial.
2). Timing of meals & breaks, same.
Energy to get in those last 250-miles is key.
— With respect, I doubt you left before 0430. Had you done so, the Average MPH would’ve been a bit higher given mainly Interstate. And a few tenths to the MPG. Don’t think this any kind of criticism, it’s to help you or anyone to think about a trip plan.
I’d say you’re feeling pretty darned good about bringing the CTD back up to par with the maintenance (some needed; some you got ahead on), the TLC (gap-covers), and the discipline to allow the CTD to do its best. Congratulations!
Debrief:
— The poly leaf spring-eye bushings are obviously a penalty when empty. Rubber (literally) absorbs vibration.
A). The counter is tire pressure where one doesn’t get below the Dodge Minimum (50-psi on my ‘04 RWD door placard). 50 is above the Load & Pressure Table Minimum (substantially).
— Second part is shock absorber design. I’d rather have a set of KONI on yours than BILSTEIN.
B). Higher than 55-psi (given scale weight confirms placarded use) won’t add enough to MPG to put up with a harsher ride, and that braking/handling/steering is about ideal (as is even tire wear).
The Ace:
PURPLE Ultimate Seat Cushion ($120-$150).
1). Can’t wear it out.
2). Eliminates all the cracks in the road.
3). Alertness seriously extended (no squirming around in seat, leaning towards one side or another to “get comfortable”).
(Shown without cover). Note recess for tailbone)
How good is it? I’m pretty sure I couldn’t drive a truck all day without it. (Old injury plus age-related health). And, at 6’2”, 200-lbs and in constant use since 2016 or so . . it won’t wear out. (I also use their Lumbar Cushion. Baby, I float on that seat!).
Truck drivers sit on air-ride seats in an air-ride cab on an air-ride suspension. My CTD is a more punishing ride at the end of a long day.
— Takes about a day to get used to it. Seat has to be re-adjusted to get best results besides ideal posture. Loose full-cut clothing, wallet in shirt, and knee-high compression socks.
Drive Wear lense sunglasses (prescription)
Summation:
— If that trip were to be run again, loading the CTD bed to about 1,000-lbs including the delivery item would give several hundred pounds on return trip to help with vibration-induced fatigue (given that FF/RR tires are at scaled safe minimum). And Ultimate Cushion (plus better posture, etc).
— Best rest breaks & food stops plan is much easier when running a route the second time.
Experience Says:
— My trip-planning 24-MPG isn’t changed by up to 1,000-lbs as tested over a 47,000-mile stretch of flat terrain (but did include having to transit Houston every 350-miles).
At 1,200-lb bed load I could record the minor Gulf Coast difference. (Which would be magnified by hilly terrain). Two-hundred pounds would be a minimum, 3-400 preferable, IMO.
Thanks, I would have never slowed down, concentrated on steering smoothly, etc.. without your coaching. I call it conscious driving! LOL
My air pressures were 50 psi front and rear. I left at 5:30 and didn't see many on the road until I reached Huntsville, AL. Nashville is/was has the most congestion.
1300 miles in 2 days plus time to unload and talk was a stretch for this 69 year old bod. I dressed for the trip. Loose baggy cloths, wallet in the tray, shoes off. I wear prescription sunglasses. Also carry a cooler with at least 2 meals going up. Drinking coffee and water.
I made frequent changes in the seat, using all the configs. I NEED one of those purple seat cushions! I'm going back to Flanagan, IL in October. I'll leave earlier, have a purple cush, lower tire pressure. The road expansion joints were tiring when empty. I drove around the pot holes as well, when possible.
I hope the P cushion helps cut down the shock load of the poly leaf spring bushings. I'll try it out soon. At the track, switching to poly or solid bushings yields faster times. OR in our case, better MPG averages.
My shocks have about 20K on them. Fronts: Rancho RS999279 adjustable and Rear: KYB KG 5196. After changing to poly leaf spring bushings, the truck stability change the most dramatically over any of the other mods. It tracks much better. I had been treating the problem with stiffer shocks, stiffer side wall tires, rear anti roll bar, poly front bushings, better anti roll bar end links, rather than addressing the rubber leaf spring bushings.
I changed out my rear brake calipers in the last 10K just because. I have a set of new front calipers I'll install with rotors and brake pads this week. Again, not because they are worn out, only 40K on them. I want fresh calipers rather that have the caliper stick and drag. I plan to change the calipers every 250K. LOL
Thanks again for your interest and sharing your wealth of information.
