can i swing runnin fbd 220s with my 64 mm charger and how will my mielage be. i was gonna do 200s but i wanna see if i can swing some 220s :peelout
that should be great. what size turbine? i ran DDP200s witha silver 62/74/14 and i could get around 18 driving normal.
Got P7100?
I had 7x14s on a garrett 64mm stg. 3 charger. thats ~240hp injectors and the charger measured 64/73/15. It would get warm at the end of the 1/4 but driving on the street you were going pretty fast once it started to get warm. I could get a hair over 20mpg on the highway with that setup.
Id go with a super b special or another 64/71/14 and the 220s should be ok.
that 64/73/15 was the charger you had before the p pump? correct??
thanks guys i already have the 64 its the aurora 4k which as far as i know is a 64/71 i believe. i just want to ditch the jammers. i might wait till i have the funds for the p pump swap and get the right pop off pressure and just do it all once with cam. commonrail tappets, etc
