Yes, 18-22psi is what cummins recommends at idle. 25-35 cruising.
When I replaced my OFV, my psi is at 28-35, all the time.
did you post in the wrong place?i have a stock plate just slid it fwd and cranked the star wheel up..lil black smoke on take off for about 5 feet then clear and will spin the dual tires in 2nd gear
absolutely no movement? even at WOT? You sure your gauge is working?it dosent change at all on my truck,,just stays at 22 psi no matter where the rpm is
im gonna try changing my main filter again...maybe got some muck in it,,,i only have about 1000 miles on it changed it back when i started having sum problems then i just changed everything elseyea mine sits at about 17 psi at idle...maybe goes to 23 wide open...either my lift pump or prefilter is clogged gonna try that and see. let me know what you find out about yours.
