No, you don't want to run 115psi with these tires on a 1 ton truck. It will ride like a log wagon. I run 60psi in the fronts and 40psi in the rears. It makes the ride smooth. It will still ride a little stiffer than stock because of the 16ply tires, but with the lower air pressures, it won't bounce around.What are safe tire pressures for the front and rear 22.5's?
115 psi seems a bit harsh for a lite truck (3500 4X4)
Thanks.
