It wouldn't take all that long for those who shouldn't be driving/can't drive to be sorted out of the system. Survival of the fittest worked great for improving the breed and make people more capable...until we wouldn't allow it, and started to give trophies to everybody.
Better corrosion protection on vehicles won't help with the damage that salt and such does to the roads.
Parking in a garage (I assume you mean heated) is actually worse from a corrosion standpoint than leaving things in a frozen state.
as much as I would love top agree with you, I cannot
the problem with letting nature sort out those that can and cannot drive in snow
problem is, new idiots will replace those that learned anything, so will always be new idiots blocking and crashing on snowy roads!
that will never solve things
and as for a garage
NO, its Not all about snow protection from rust , but I can assure you having DRY pl;ace to store a vehicle in will add yrs of life to it over parking in the elements all yr!
park your vehicles on wet ground all yr, or damp ground, gravel grass, or such
and that alone will hold more moisture to speed rusting process up, add salt to the mix and even faster rusting out of things!
so havinga garage can be HUGE difference, liek it or not?
if you really don't believe there are better coatings out there that can control rust, your kidding yourself
I have used many that made HUGE differences
coasting metal parts on salt plow rucks with POR 15, a good paint over that and some RP342 over that
and things last substantially longer without rust, over just paint, and I mean MANY many YRS longer!
so, without a doubt, it would be WAY easier to add better rust protection that trying to cure idiots on the roadways,a s much as I would love to see ONLY folks that know how to drive better on roadways, that will NEVER happen,
too many variables in humans that cannot be controlled!
and if you think OEM's cannot do better coatings, think again, some already do NOW!!
have you ever seen HD trucks, dump trucks, tractor trailers things with basically a CDL needed to drive? as an example
and there are plenty of BAD cdl drivers out there too! cannot seem to control that and they are required to do way more testing?? so, getting ruid of BAD drivers is not a solutiion that is honestly viable, even if it seems logical!
BUt these vehicles they run in salt belts and have WAY less rust issue's ,,
WHY??
because they come directly from factory with , better METAL< and better coatings over it, which stops and prevents them from failing as fast to salt and rusting out,!
as too basic cars and trucks made for average drivers.consumers!
so, there is already proof out there its possible to be done!, as its being done on SOME vehicles now!
but just for commercial drivers it seems!(and I had a CDL too by the way)
so, since we cannot control drivers abilities, we can control what products are used in making vehicles, maybe again, having as an OPTION to buy a better coated vehicles
is a more logical and possible solution, and maybe even an expectation we customers should have on new vehicles with these crazy high costs of vehicles these days.
there are a lot o foklks living on FIXED income that don;t have ability to go back to work, due to crazy current prices of things
least they should be able to expect is for things to last and not rot away so fast!
