Hello wondering if there is any difference on the 6.7 motors I'm already planning on using the original ecm and wiring harness that is in the truck.
Ok thank you very much that's exactly what I was looking for.I would avoid the 2019+. Lifter failure is an ongoing issue, and engine uses different pistons, injectors, connector tubes, fuel rail, fuel lines, and fuel pump.
Stick with 2007-2018 for something drop in.
