2018 CCLB G56 Laramie
I recently picked up a G&R fuel filter relocation kit and engine filter delete. Running the Cat filter and water separator with the drain. It’s for a 2018 and correct me if I’m wrong but I have two WIF sensors, one on the engine mounted filter and one on the rear bed filter. I know I can get a WIF cooler for the engine mounted sensor but do I need one for the rear? If so, where can I get one?
17 3500 Laramie CCLB
There is one WIF sensor in the filter in the rear. The Cat filter is no better than the OEM.
· Rear Admiral Rickard Onmi
2018 Ram 3500 CCLBSRW
There are other kits out there that retain the rear WIF sensor, and put it in the filter block for the rear filter. and @Glacier Diesel Power makes a great full kit to replace the front filter with a spin on style and includes everything you need to swap it out without creating codes
