1 - 20 of 31 Posts
@Jimmy07 and I have been working on troubleshooting an issue where the 8.4" UConnect radio's reverse camera does not turn on when shifting the manual (g56) transmission into reverse. I am hoping someone on the forum here has a 2018 Ram with the factory 8.4" radio, and that they can get a copy of their vehicle configuration sent to either I or Jimmy. This can be done using AlfaOBD.
Thanks!
Reactions: CR_Hunter
My 16 is a laramie g56 with the 8.4. Might help might not but this winter when I was doing a bunch of work to the truck I removed a ground from the outside of the driver frame rail under the driver front door and the reverse camera didn’t work. Maybe take a look at that ground
Can this be done with the Demo version of Alfa OBD, or do you need the full version?
I just installed the "upgraded" radio from my smaller 5" radio. What we are currently seeing is that the camera would work just fine prior to the installation, although now the camera does not turn on with the new radio. I wonder if the ground wire is needed for the new one.. Thanks for the info!
I am not sure at this moment, I would have to wait to check later this afternoon when I get home. Maybe @Jimmy07 could confirm if you can pull the data using the Demo version of AlfaOBD?
Reactions: tomk
This is going to REALLY narrow the chances down, but what we actually need is a 2018 G56 owner with a factory equipped 8.4” radio AND AlfaOBD. It has to be a 2018, because this is the only year with the CarPlay/AA radio in a G56, and it’s that particular radio that the camera doesn’t automatically come on in reverse when it is transplanted into a G56 truck. 2013-2017 8.4” radios don’t have this problem when swapped into G56 trucks. As if this isn’t already like finding a needle in a haystack- it would be even better if it’s the windows version of AlfaOBD.
Rear Admiral Rickard Onmi
18s will also need the bypass harness installed in their truck for Alpha to be able to write anything, can Alpha read the factory settings of an 18 without the bypass harness @Jimmy07 ? If so, i have alpha and am located in Spokane WA if anyone with an 18 is willing to let me plug in a read their truck. If it needs the bypass harness i could pull mine and install temporaily in yours, but would suggest you get your own due to the current heat + my available time + my own laziness and preference to work on other projects. But if someone has an 18 and gets the bypass harness i can do the read and do any modifications they would like done with Alpha after we record the stock settings, if you are in the Spokane / CDA general area of course
I have updated the top thread post a bit to help find us a 2018 model hopefully! Unfortunately, there's no model above 2018 either, since the manual is no longer available! Harsh!
A bypass is not needed to read and upload the BCM system status. I think this can also be done with the demo mode, but you only get a 15 minute shot to do it.
Discussion Starter #9
I can also offer the same services for anyone near the Wenatchee WA area if necessary. I know there's some manual trucks around me, but not sure of age or if they use the site! Going to have to end up taking a newspaper ad out!
Also, along with the BCM system status, we need the BCM system ID read, so I can see the ECU part number and the ECU hardware number.
If someone gets a hold of me or i find a truck i can do this on i will get a hold of you to make sure i get everything you need and what not.
So between us, we have most of Washington covered. LOL Although chances are it'll be somoene in Ohio that has a truck they'd be willing to do it on. Guess we will see (although i'd keep on this side of the mountains if i were you, with everything going on. Then again with all the rain we've had and the heat getting turned up, it won't be long until things get smokey out by you.)
Discussion Starter #12
Smoke is already among us. We've had a number of fires burning this month. Just had a ~10k acre fire blow up in a field near our farm area. Made it within 200 yards of the property. Course, that was on the windiest weekend of the whole summer so far! The west side has always been and always will be a mess. Took a ride with the father-in-law to pick up a pup trailer with the semi in Ravensdale. Awful as usual there on that side. 18 and I-90 is just blocked up 24 hours a day it seems.
I'm hoping to have a couple more weeks without smoke, but if it's already around out there we probably only have another week or two at most before it starts hitting us. I don't remember the fires and smoke being so bad when i was a kid, but maybe i just didn't notice it. Seems like they got worse in the last 5-10 years
Ask and you shall recieve.
BCM config from my 2018 with g56 and factory installed 8.4
___
Reading faults for: Body Control Module MY 2018
___
Faults reported:
2019/12/18 18:31:41.832
Faults found.
B2303
Error code: B2303
Wiper Park Switch Input
Short circuit to ground
Last test completed positively
Error intermittent
Failure warning lamp 'ON': Not requested
___
Tested device: Body Control Module MY 2018
___
2019/12/18 18:32:06.201
VIN - Current: 3C6UR5DL5JG322663
VIN - Original: 3C6UR5DL5JG322663
ECU serial number:
ECU Part Number: 68357472AD
Hardware number: 68357472AD
Hardware Supplier Identification: Continental
Software Logical Block Supplier Identification: Continental
Active Diagnostic Status Of ECU: Running in Application mode
Gateway: Yes
Plant/Service Mode Parameters: Shipping Status: Customer Mode
Vehicle Configuration Programmed Status: Yes
Last Programmed Status: Manufacturing
ECU Qualification:
Sense-Ambient Light Dimmer Wheel: No
Sense-Reverse Switch: No
Sense-Door Lock Switch Front Driver: Yes
Sense-Door Lock Switch Front Passenger: Yes
Sense-ERS Switch: No
Sense-Flipper Glass Ajar: Yes
Sense-Fuel Level Sensor #2: No
Sense-Hood Ajar Switch: No
Sense-Hard Top/Stealth Input: No
Sense-Liftgate/Trunk Ajar: No
Sense-Trunk/Flipper Glass Release Switch: Yes
Sense-Rear Wiper Park Switch: Yes
Sense-Washer Fluid Level: Yes
Sense-Flipper Glass Release/Sunshade Switch: Yes
Sense-ESP Off Switch: Yes
Sense-Cargo Lamp Switch: Yes
Police Passenger Unlock Motor Present: No
Control-Headlamp Leveling: No
Control-Baggage Comp Lamps: Yes
Control-Diesel Cabin Heaters 1-3: No
Control-ESCL: Yes
Control-Diesel Fuel Heater Relay: Yes
Control-Flipper Glass #2: No
Control-Foot Well Lamps: Yes
Control-Front Fog Lamps: Yes
Control-Headlamp Washer Motor: No
Control-Passenger Airbag Off LED: No
Control-Rear Fog Lamps: No
Control-Rear Turn Lamps: No
Control-Rear Wiper Motor/Flipper Glass #1: No
Control-Run/ACC Relay #2: Yes
Control-Side Repeaters: No
Control-Sunshade: No
Control-Trunk/Flipper Glass Relay: No
Control-UGDO Feed: Yes
Control-Trailer Tow: Yes
Control-Dedicated DRL: No
Control-VTA Indicator Request: Yes
Control-Passenger Airbag LED: No
Adjustable Pedals Present (Non-memory): No
Inverter Present: Yes
Intrusion System Present: Yes
Remote Start Present: No
Tip Start Present: No
HID Headlamps Present: Yes
Auto Headlamps Present: Yes
Rain Sensor Present: No
Remote Compass Present: No
EC Mirror Present: Yes
Cruise Feature Present: Yes
RKE System Present: Yes
SKIM System Present: Yes
Police Vehicle: No
Military Lighting: No
AC Present: Yes
Rear Doors Present: Yes
Electronic Shifter Power Feed Present: Yes
__
Customer Customisable Configuration set in the Body Computer:
Customer Programming Features:
Unlock all doors on 1st press: Set
Sound Horn on Lock: Set
Flash Lamps on Lock: Set
Headlamps on with Wipers: Not set
Auto Lock: Set
Auto Unlock: Set
Door Alert Enable: Not set
Auto Wipers: Not set
Illuminated Approach Time: 0 sec
Headlamp Delay Time: 30 sec
Accessory Delay Time: 45 sec
Ambient Dimmer Level: 0.50 %
Daytime Running Lamps: Set
EC Mirror Auto Dim: Set
PE Unlock All Doors or Approach Door: Not set
Accessory Delay Active: Not set
Remote lowering horn enabled: Not set
Remote lowering lights enabled: Not set
Sound Horn on Remote Start: Set
Auto Relock: Set
Static Gridlines Enabled: Set
Dynamic Gridlines Enabled: Set
Sound Horn On Lock Status: Chirp on 1st press
Customer Programming Switches:
Rear View Camera Dynamic Grid Lines Enabled: Not set
LIN Module Customer Programmable Features:
Rear View Camera Static Grid Lines Enabled: Not set
Rear View Camera Dynamic Grid Lines Enabled: Set
__
Vehicle Configuration set in the Body Computer:
Vehicle Config 1:
Model Year: 2018
Vehicle Line: DJ
Country Code: Canada
Left/Right Hand Drive: Left Hand Drive
Remote Start Present: Not set
Drive Configuration: Selectable 4wd
Emode Present: Not set
Auto High beam: Not set
Body Style: 4-Door Pickup
Maximum Vehicle Speed: 255 km/h
Shifter Type: Not applicable
PTS Display Type and Location: Instrument Cluster PTS Display
Performance Pages Present: Not present
Special Packages: Sport/SLT+/Laramie
Headrest present: Not set
UREA/SCR System Present: Set
PTS Configuration: Rear
Rear View Camera: Set
CHMSL camera: Set
Hill Descent Feature Present: Not set
Select Speed Control Feature Present: Not set
Vehicle Config 2:
Power Inverter Type: Latching Switch
Thatcham Present: Not set
Run flat tires present: Not set
Maserati vehicle mode: Normal
Pass. Airbag Disable Switch Present: Not set
Rain Sensor Present: Not set
SKIM System Present: Set
Air Conditioning Present: Set
Cruise Feature is Present: Set
Flipper Glass Present: Not set
Full Size Spare: Not set
Off Road Capable: Not set
Special Packages: No
Special Packages: Not defined
ECO Indicator Present: Not set
Drive mode feature configuration: Not set
Memory drive mode sub-feature configuration: Not set
ESC drive mode sub-feature configuration: Not set
ECM drive mode sub-feature configuration: Not set
Secure park feature present: Not set
Performance & Gear Shift Indication: No
Maximum Load Inflation Pressure Rear Tire: 80 PSI
Maximum Load Inflation Pressure Front Tire: 65 PSI
Light Load Inflation Pressure Rear Tire: 0 PSI
Light Load Inflation Pressure Front Tire: 0 PSI
Vehicle Config 3:
Police Lighting Feature: Not set
Power Lift Gate Present: Not set
Power Right Sliding Door Present: Not set
Power Left Sliding Door Present: Not set
RKE System Present: Set
Sunshade Present: Not set
T-Case Type: 44-45, 44-46 with Sync, 44-48 with Sync/ Analog Tranfer case 244 / BW4446 With Synchro/ Transfer Case BW 44-45
Fuel Capacity: 117 Liters
Wheel Base: Long wheel base
FOBIK Safe Enable: Not set
ELV Present: Not set
Window Express Feature Configuration: Front windows express only
Adjustable Pedal Feature Present (non-Memory): Not set
Auto Headlamp Feature Present: Set
Door Alert Feature Present: Not set
Two Fuel Sending Units Present: Not set
Vehicle is an SRT: Not set
Disable Display of Radio Clock: Not set
Chassis Type: Type 17
Display Outside Temperature Present: Set
HVAC Configuration: Dual Zone ATC
Vehicle Brand: Ram
Display Compass Heading Present: Set
Interior EC Mirror Present: Set
ESCL system present: Not set
High Intensity Discharge Head Lamps: Set
Secondary Lock Present: Not set
Liftgate/Trunk Type: Trunk
Collision Mitigation System present: Not set
Forward Collision Warning present: Not set
Base TPM system present: Not set
Premium TPM system present: Set
Paddle Shift Feature Present: Not set
Sport Mode Present: Not set
Auto Park Present: Not set
Passive Entry Present: Not set
Keyless Go Present: Not set
Vehicle Config 4:
Transfer Case High Ratio: 1.00
Axle Ratio: 3.42
Transfer Case Low Range Reduction Ratio: 2.64
Dynamic Tire Circumference: 2640.00 mm
Vehicle Config 5:
Steering Ratio at zero: 0.00
Steering Ratio at Positive Angle 1: 0.00
Steering Ratio at Positive Angle 2: 0.00
Steering Ratio at Positive Angle 3: 0.00
Steering Ratio at Positive Angle 4: 0.00
Steering Ratio at Positive Angle 5: 0.00
Luci feature present: Not set
Dual Rear Wheel (DRW) Vehicle Present: Not set
Non-Regulated Tire Pressure Information System: Not set
Ambient temperature sensor location: Not defined
Rear door lock switch present: Not set
Wait to Start Feature Present: Not set
Speed Limiter Present: Not set
Seat Belt Reminder Module Present: Not set
Child Display Feature Present: Not set
Off-Road Pages Present: Not set
Ambient Lighting Feature Present: Not set
Semi-Automatic Parking System Present: Not set
Park With Stop Present: Not set
Vehicle Config 6:
Steering Ratio at Negative Angle 1: 0.00
Steering Ratio at Negative Angle 2: 0.00
Steering Ratio at Negative Angle 3: 0.00
Steering Ratio at Negative Angle 4: 0.00
Steering Ratio at Negative Angle 5: 0.00
Dynamic Tire Circumference Front: 65535 mm
Analog Door Sensor Configuration: No Doors with Analog Sensors
Brake type configuration (M156/7): Signal Not Available
Air Quality System Present: Not set
Vehicle Config 7:
Lane Departure Warning present: Not set
Transmission drive mode feature: Not set
Paddles lock-out feature: Not set
Dynamic steering torque present: Not set
Super trac pack present: Not set
E-shifter present: Not set
Automatic transmission type: Not Programmed
Shift feature autostick / electronic range select: None
Teen Key Feature Present: Not set
Full Central Vision Processing: Not set
Full Speed Range forward collision warning plus system present: Not set
Type of adaptive Cruise Control (ACC) system present: No
ASCM contains suspension: Not set
ASCM Active Damping: Not set
Transmission Neutral Hold Feature Present: Not set
Red Key Feature Present: Not set
Active Blind Spot Present: Not set
Axle Locker Configuration: No Axle Locker
Transmission Type: Manual
Park Brake Type: Mechanical park brake - hand or foot
TPMS Configuration: NHTSA enable warning
Vehicle Config Customer Settings Menu 1:
Park Assist customer settings menu: Feature 1 - 2 option
Park assist brake customer settings menu: Not set
Park Assist Front Volume customer settings menu: Not set
Park assist rear volume customer settings menu: Set
Electric power steering customer settings menu: Not set
Forward collision warning customer settings menu: Absent
Forward collision mitigation braking customer settings menu: Not set
Sound horn with remote lock customer settings menu: Feature 2 - 3 option
Sound horn with remote start customer settings menu: Not set
Sound horn with remote lower customer settings menu: Not set
CHMSL line customer settings menu: Not set
Auto-On Driver Comfort CSM: Feature 1 - 2 option
Auxiliary Switches CSM: Absent
Rear view camera gridlines customer settings menu: Dynamic
Police Passive Entry Settings CSM: Not set
Power accessory delay customer settings menu: Set
Adaptive front light system customer settings menu: Not set
Ambient dimmer customer settings menu: Not set
Tire jack mode customer settings menu: Not set
Air suspension warning customer settings menu: Not set
Automatic aero mode customer settings menu: Not set
Auto high beam customer settings menu: Not set
Auto park customer settings menu: Not set
Blind spot alert customer settings menu: Not set
Capacity unit customer settings menu: Not set
Clock display customer settings menu: Not set
Compass calibration customer settings menu: Not set
Consumption unit customer settings menu: Not set
Distance unit customer settings menu: Not set
Auto door lock customer settings menu: Set
Auto door unlock customer settings menu: Set
Daytime running lights customer settings menu: Not set
Easy exit seat customer settings menu: Not set
Auto entry exit mode customer settings menu: Not set
EPB service mode customer settings menu: Not set
Flash lamps with lock customer settings menu: Set
Headlamp drop customer settings menu: Not set
Headlamp off delay customer settings menu: Set
Headlamps on with wiper customer settings menu: Set
Hill start assist customer settings menu: Set
Illuminated approach customer settings menu: Set
Lane departure torque customer settings menu: Not set
Lane departure warning customer settings menu: Not set
Flash lights with remote lower customer settings menu: Not set
Nav turn by turn customer settings menu: Not set
Passive entry customer settings menu: Not set
Performance shift enable customer settings menu: Not set
Performance shift rpm customer settings menu: Not set
Power liftgate chime customer settings menu: Not set
Power unit customer settings menu: Not set
Pressure unit customer settings menu: Not set
Power take off customer settings menu: Not set
Rain sensitive wipers customer settings menu: Not set
Rear camera customer settings menu: Set
Vehicle Config Customer Settings Menu 2:
Rear view camera delay customer settings menu: Set
RKE linked to memory customer settings menu: Not set
RKE unlock customer settings menu: Set
Speed unit customer settings menu: Not set
Tilt mirror in reverse customer settings menu: Not set
Torque unit customer settings menu: Not set
Trailer selected customer settings menu: Set
Trailer name customer settings menu: Not set
Trailer type customer settings menu: Set
Transport mode customer settings menu: Not set
US/metric customer settings menu: Set
Wheel alignment customer settings menu: Not set
Fuel Saver customer settings menu: Not set
Tempature Unit customer settings menu: Not set
Hold And Go customer settings menu: Not set
Auto Power Folding Mirrors customer settings menu: Not set
Paddle Shift CSM: Not set
Speed Warning CSM: Absent
LDW On/Off CSM: Not set
Park Assist Type CSM: Not set
EPB On/Off CSM: Not set
Passenger Airbag On/Off CSM: Not set
FCW Switch CSM: Not set
CBC Configurable Inputs and Outputs:
Ambient Light Dimmer Wheel Input Present: Not set
Backup-Reverse Switch Input Present: Not set
ERS Switch Input Present: Not set
Fuel Level Sensor #2 Input Present: Not set
Hood Ajar Switch Input Present: Not set
Inverter Status Input Present: Set
Manual T-Case Present: Not set
Snow Plow Enable/Disable: Set
Washer Fluid Level Sense Signal Input Present: Set
ESM Present: Set
Adjustable Pedal Motor Relay Output Present: Not set
Diesel Cabin Heater #1 Output Present: Not set
Diesel Cabin Heater #2 Output Present: Not set
Diesel Cabin Heater #3 Output Present: Not set
Diesel Fuel Heater Relay Output Present: Set
Right Dedicated DRL Lamp Output Present: Not set
Left Dedicated DRL Lamps Output Present: Not set
Foot Well Lamps Output Present: Set
Front Fog Lamps Output Present: Set
Headlamp Washer Motor Control Output Present: Not set
Inverter Enable Relay Output Present: Set
Relay LSD Spare #1 Output Present: Not set
Relay LSD Spare #2 Output Present: Not set
SNOW PLOW LSD #3: Not set
IOD ON LSD Output Present: Not set
Snow Plow Park Lamps: Not set
Rear Fog Lamps Output Present: Not set
Rear Park Lamps Output Present: Set
Rear Turn Lamps Output Present: Not set
Rear Turn Lamp Output Present (NA on LA): Not set
Run-ACC Y Relay #2 Output Present: Set
Side Repeaters Output Present: Not set
Ram Box/Tail Gate Lock Present: Set
Ram Box/Tail Gate Unlock Output Present: Set
Trailer Backup Lamps Output Present: Set
Trailer Tail Lamp Relay Ctrl Output Present: Set
Trailer Turn_Stop Relay Ctrl LT Output Present: Set
Trailer Turn_Stop Relay Ctrl RT Output Present: Set
UGDO Feed Output Present: Set
VTA Warning LED Output Present: Set
Vacuum Switch Input: Set
Ignition UNLOCK RUN START Present: Set
IOD RELAY OFF HSD Present: Not set
IOD RELAY ON HSD Present: Not set
Ambient Temperature Sensor Present: Not set
CBC Features Configuration:
Tip Start Enabled: Not set
Dual Start Relay System Present: Not set
Wiper Service Position Enabled: Not set
AUX High Beam Present: Not set
Trailer Tow Present: Set
Quad Headlamps Enable: Set
Horn Chirp Allowed: Set
Bi Xenon Headlamps Enable: Not set
Hazard Lamp Configuration: Latching Switch
Park Lamp Loadshed Enable: Set
Front Fog Lamp Dropout Enable: Not set
Combined Rear Lighting Enable: Set
Side Repeaters Enable: Not set
One Touch Lane Change: Set
Exterior Light Loadshed Enable: Set
Front Wiper Park Enable: Set
Rear Wiper Park Enable: Not set
Reversible Washer Pump Enable: Not set
Single Element Tail Lamp: Not set
DRL Configuration: Canada DRL
DRL Lamp Location: Turn Signal DRL
DRL Dropout Enable: Set
Tunnel Detection: Not set
Rear Lighting DTC Disable: Not set
LED Reverse Lamps Present: Not set
LED Stop Lamps Present: Not set
LED Rear Turn Lamps Present: Not set
LED Tail Lamps Present: Not set
LED Rear Fog Lamps Present: Not set
LED License Lamps Present: Not set
LED Front Turn Lamps Present: Not set
LED Front Fog Lamps Present: Set
LED Dedicated DRL Present: Not set
LED Low Beam Lamps Present: Not set
LED High Beam Lamps Present: Not set
LED Front Park/Marker Lamps Present: Not set
VTA Hood Ajar Monitoring: Not set
TCSM Present: Set
Headlamp Wash Spray Duration (at 100 ms intervals): 2000 ms
Headlamp Wash Interval: wash cycle #11
Headlamp Wash Shot: Single
Front Wiper Wipes After Wash: 2 Wipes
Headlamp Washer Low Fluid Shut-Off Enable: Set
Side Mirror Repeaters used as side markers: Not set
Intermittent Wiper States: 5 Intermittent Wiper position Switch
LED CHMSL Lamp Present: Set
ECU Configuration 3:
Configuration messages status 3: Programmed
Rear Camera Present: Set
DRL customer setting enable/disable: Not set
Front Heated Seats Present: Set
Front Ventilated Seats Present: Not set
Destination: Canada
Cabin Equalization Curve Number: Crew Cab Premium (Alpine 12-ch) (DS)
Hill Start Assist Customer Setting Option Present: Not set
Radio APPS/Clari-Fi Present: Not set
SDAR Travel Link Feature Present: Not set
DAB/DMB Present: Not set
Heated Steering Wheel Present: Set
Surround Sound Feature Present: Set
Power Door Locks Present: Set
Antenna Type: Passive Primary and no secondary antenna
Disable CD Eject: Not set
DTV Front Camera Present: Not set
DTV Side Camera Present: Not set
Steering Wheel Switch Configuration: Brand Focus Steering Wheel
Radio Display On/Off Softkey Present: Not set
Microphone Tuning Parameter: Absent
Microphone Configuration: 2 microphones
Microphone Type: Peiker 300 mv
External Port Type: AUX + USB + extra USB
Splash Screen Type: None/Vehicle Brand
ECU Configuration 4:
ERS Available: Not set
Rear Wheel Dually: Not set
Max Gear: Not available
IPC Feature Configuration: Not available
Heated Seat Present: Set
Split Shaft Present: Not set
Vehicle Class: Not defined
Fuel Capacity: 0 Liters
Gear Display: Disabled
Wireless Configuration:
Tip Start Present: Not set
AP5 Trunk: Not present
Airport Scenario Trunk Set: Not set
AP1 Left Front: Not present
AP2 Right Front: Not present
AP3 Left Rear: Not present
AP4 Right Rear: Not present
Doors Configuration:
Global Up: Not set
Global Down: Not set
Sun Shade: Not set
Puddle Lamp Present: Not set
Rear Door pre short drop behavior: Not set
Passenger Window Lockout: Not set
Folding mirrors present: Set
Heated Mirrors: Set
Mirror turn signals present: Set
Driver Memory Mirrors Present: Not set
Passenger Memory Mirror Present: Not set
Electro-chromatic driver mirror present: Not set
Electro-chromatic passenger mirror present: Not set
Tow Mirror Present: Set
Blindspot Mirror Present: Not set
Mirror Approach Lights Present: Set
Door map pocket LED present (Ambient Lights): Not set
Door Courtesy Lamps Present: Not set
Window Motor Type: Not set
Window Hall Sensors Present: Not set
Door handle LED present (Ambient Lights): Not set
Frameless Window Present: Set
Memory Configuration:
Memory Adjustable Pedals Present: Not set
Tilt/Telescope Steering Present: Not set
Memory Seat Present: Not set
Rear Heated Seats Present: Not present
Front Vented Seats Present: Not present
Heated Steering Wheel Present: Present
Heated Seat Material Type: Cloth
Heated Wheel Material Type: Full Leather
Brake Configuration:
Wheel 18 inch overall ESC Maserati: Set
Powertrain Configuration:
Vehicle is equipped with Dosing Control Unit: Set
Vehicle is equipped with Variable Geometric Turbo: Set
ECO Mode Configuration: Remember previous state with Ignition Key Cycle
Dual Alternator Present: Not set
Safety Configuration:
ODS Present: No
ORC - Special Type: DS 2 door, DJ 4 door, DF
ORC - Calibration Selection: Not defined
Integrated EPP Present: No
BUX vehicle: No
CBC Exterior Lighting Calibrations:
Auto Headlamp ON Threshold: 3.31 V
Auto Headlamp OFF Threshold: 2.55 V
Left Side DRL Voltage Target: 7.4 V
Right Side DRL Voltage Target: 7.4 V
Left Low Beam Voltage Regulation: 14 V
Left High Beam Voltage Regulation: 14.2 V
Right Low Beam Voltage Regulation: 14 V
Right High Beam Voltage Regulation: 14.2 V
Left Front Corner Voltage: 13 V
Right Front Corner Voltage: 13 V
Left Rear Corner Voltage: 13 V
Right Rear Corner Voltage: 13 V
LIN and Miscellaneous Configuration:
Alert on no Reply: Not set
Alert On System Fault: Not set
Alert On Search Timeout: Not set
Auto Relock Time: 60 sec
Compass Mounting Angle: 0 Deg
Snow Plow Enable: Not set
Panic Enable: Set
Compass Mounting Orientation: Set
Washer Fluid Level Voltage Threshold: 4.46 V
Fobik Safe Alerts Per Ignition Cycle: 32
UCONNECT Access Mirror Buttons Present: Set
RCM Present: Not set
Humidity Sensor Present: Not set
Manual Trans Present: Set
Smart Beam Present (AHBM): Not set
DC to DC Converter Present: Not set
ASBM Present: Set
VTA System Present: No
EOM Present: Set
DC to DC Converter #2 Present: Not set
Illuminated Approach Interior Lighting Target Percent: 150 (75%)
Illuminated Approach Headlamp Target Percentage: 165 (82.50%)
Illuminated Approach Taillamp Target Percentage: 165 (82.50%)
Illuminated Approach Interior Lighting Ramp Up Time: 150 (3000 ms)
CRVMM Present: Not set
IBS Configuration:
IBS Quiescence Current Limit: -250 mA
IBS Minimum Voltage Limit: 5.00 V
IBS Minimal Charge Limit: 10.00 A/H
CBC I/O Usage Configuration:
Connector F Pin 22: Analog Spare Input #1 Usage: Sunshade Switch
Connector F Pin 5: Left Rear Fog Lamp/High Beam Shutter Usage: Disabled
Connector E Pin 39: Right Rear Fog Lamp/High Beam Shutter Usage: Disabled
Left High Beam Feed Usage: Left High Beam (0)
Right High Beam Feed: Right High Beam (0)
Front Driver Door Ajar Switch Signal Usage: Disabled
Connector F Pin 28: Front Passanger Door Ajar Switch Usage: Disabled
Connector F Pin 27: Left Rear Door Ajar Switch Signal Usage: Disabled
Connector F Pin 31: Right Sliding Door Ajar usage: Disabled
Spare LSD Relay #1 Usage: Snow Plow Low Beam Control
Spare LSD Relay #2 Usage: Snow Plow Park Lamp Control
Connector A Pin 11: Hood Ajar Switch Usage: 1K parallel resistor
Connector E Pin 21: IOD RELAY ON LSD: Snow Plow High Beam Control
IOD HSD Relay On Usage: Snow Plow Left Turn Lamp
IOD HSD Relay Off Usage: SNOW PLOW RIGHT TURN (0)
Stop/Start Enable Switch Present: Not set
ITM Configuration:
Siren: Set
Ultrasonics: Set
Tilt: Set
Cluster Configuration:
Fuel Tank Calibration, Full: 91%
Fuel Tank Calibration, Empty: 2%
Fuel Tank Calibration, LFW: 8%
Cluster Configuration 2:
Fuel Tank 2 Calibration, Full: 91%
Fuel Tank 2 Calibration, Empty: 2%
Fuel Tank 2 Calibration, LFW: 8%
2014 CBC I/O and Features Configuration:
Analog Spare Input #2: Not present
Analog Spare Input #3: Not present
Analog Spare Input #4: Not present
Analog Spare Input #5: Not present
Analog Spare Input #6: Not present
Truck Bed Lighting Feature: Bed Lighting Feature Present
High Beam Lamps Open Circuit DTC Enable: Not set
Dedicated DRL Lamps Open Circuit DTC Enable: Not set
License Lamp Open Circuit DTC Enable: Not set
Reverse Lamps Open Circuit DTC Enable: Not set
Stop Lamps Open Circuit DTC Enable: Not set
CHMSL Lamp Open Circuit DTC Enable: Not set
Front Park Lamps Open Circuit DTC Enable: Not set
Rear Park Lamps Open Circuit DTC Enable: Not set
Front Fog Lamps Open Circuit DTC Enable: Not set
Rear Fog Lamps Open Circuit DTC Enable: Not set
Baggage (Cargo) Lamp Output Disabled with vehicle: Not set
CHMSL Lamp Output Disable: Not set
IOD Relay Voltage Sense: Not set
Manual Door Locks Present: Not set
Rain Sensor Module #2 Present: Not set
Humidy Sensor Long Present: Not set
Auto High Beam Module Location: None
License Lamp Disabled: Not set
Right Rear Turn Signal Usage: Right Rear Turn Signal
Left Rear Turn Signal Usage: Left Rear Turn Signal
Acceleration/Braking/Steering values::
Excess Lateral Acceleration Factor: Filter Off
Average Last Lateral Acceleration Values: Averaging 15
Excess Longitudinal Acceleration Factor: 7.5
Average Last Longitudinal Acceleration Values: Averaging 15
Brake Smoothing Duration: 31 period(s)
Brake Smoothing Factor: 1
Steering Smoothing Duration: 3 period(s)
Steering Smoothing Factor: 2
Steering Smoothing Threshold: Filter Off
Brake Smoothing Threshold: 375 Nm
Maximum Longitudinal Change: 1.0 degrees
Maximum Lateral Change: Filter Off
Acceleration Threshold: 1.5 m/s2
Acceleration Factor: 5.00
Nose Dive Threshold: 280 degrees
Nose Dive Factor: 0.50
Radio Features Configuration:
Radio Speaker Open Circuit Disable (LF): Not set
Radio Speaker Open Circuit Disable (RF): Not set
Radio Speaker Open Circuit Disable (LR): Not set
Radio Speaker Open Circuit Disable (RR): Not set
ANC Calibration Parameter Data Set: Not Programmed
Defrost Mode and Heated Mirrors Present: Mirror Only
Auto Dimming Mirror Hard Button Present: Not set
Trailer Hitch Camera: Set
Programmed ECUs: Cabin Network:
RBSS Right Blind-Spot Sensor: Not set
LBSS Left Blind-Spot Sensor : Not set
BCM Interior Bus: Set
CSWM Comfort Seat Wheel Module: Set
HSM Heated Seat Module: Set
DDM Driver Door Module: Set
PDM Passenger Door Module: Set
DCM_RL Door Control Module Rear Left: Not set
DCM_RR Door Control Module Rear Right: Not set
HVAC Heating, Ventillation & Air Condition: Set
MSM Memory Seat Module: Not set
PLGM Power Liftgate Module: Not set
VTM Vehicle Tracking Module: Not set
PSDML Power Sliding Door Module Left: Not set
PSDMR Power Sliding Door Module Right: Not set
FSM Fold Stow Module: Not set
PTCM Power Top Control Module: Not set
RBC Regenerative Brake Controller: Not set
DTV Digital Television: Not set
Radio: Set
Clock: Not set
VSIM Vehicle System Interface Module: Not set
ITM Intrusion detection: Not set
AMP Audio Amplifier: Set
ETM Entertainment Telematic Module: Not set
HFM/CTM Hands Free Module/Convergence telematic: Not set
ICS Integrated Center Stack: Set
VES2 Second Row Screen: Not set
VES3 Last Row Screen: Not set
CRSM: Not set
HVAC_R Rear Heating, Ventillation & Air Condition control: Not set
CVPM Central vision processing module: Not set
Programmed ECUs: P/T Chassis Network:
ACC Adaptive Cruise Control: Not set
ADCM Active Damping Control Module: Not set
AHLM/AFLS Headlamp Leveling: Not set
ASCM Air Suspension Control Module: Not set
BCM (PT) Body Control Module: Set
DTCM Drive Train Control Module: Set
ECM/PCM Engine/Powertrain Control Module: Set
EPS Electric Power Steering: Not set
ESM Electronic Shift Module: Not set
ABS: Set
EPB Electronic Parking Brake Module: Not set
RFH Radio Frequency Hub: Set
IPC Instrument Panel Cluster: Set
ACC/DASM Adaptive Cruise Control: Not set
FDCM Final Drive Control Module: Not set
EPPM Electronic Pedestrian Protection Module: Not set
ORC Occupant Restraint Control: Set
PTS Parktronics: Set
RBT Driver: Not set
RBT Passenger: Not set
SCCM Steering Column Control Module: Set
ELSD Electronic Limited Slip Differential: Not set
TCM Transmission Control Module: Not set
TPM Tyre Pressure Module: Not set
PASS (PT): Not set
AFLS Discharge lamps: Not set
ITBM Integrated Trailer Brake Module: Set
OCM Occupant Classification Module: Not set
FFCM Front Facing Camera Module: Not set
HCP Hybrid Control Processor: Not set
ANC Active Noise Cancelation: Not set
Programmed Network Configuration - Audio / Telematics Network:
AMP Audio Amplifier: Not set
ICS Integrated Center Stack: Not set
PASS (A/T): Not set
SDARV Satellite Video Receiver: Not set
DVD Changer: Not set
HFM Hands Free Module: Not set
Programmed ECUs: Hybrid LAN Network:
APM Accessory Power Module: Not set
BPCM Battery Pack Control Module: Not set
MCPA Motor Control Processor A: Not set
MCPB Motor Control Processor B: Not set
__
No i dont own a copy of the windows version. I would get a copy and get it for you but i work for the coast guard and currently on shift till next wed. If you need it after that send me a message
No worries. I’ll see what I can find with what we have here, and go from there.
forgot to mention too, my truck also has the third brake light camera, so while going through that log some of the entrys will reference that as well. There is like a dozen things that reference the rear camera
Discussion Starter #20
Thanks a ton @RichardCalvin Hopefully something will come out of this. I trust Jimmy is digging into it to try and reference an issue. The cargo camera will be helpful too, as I intend on adding that one of these days!
1 - 20 of 31 Posts
