1 - 20 of 20 Posts
So I've noticed my 2018 3500 has no rear reading lights; only a single rear dome with no switch. Is there at least a replacement light with a switch so rear passengers can see without having to turn all the interior lights on?
Thanks
That light works as a reading light, you just have to push one side of it to turn it on, at least on my truck.
Thanks
Yes, there is a switch, you just push in on the lens to turn it on.
My truck is a tradesman. There's just one rear dome light, all the way at the back of the roof. It comes on when you open the doors or turn on "all lights" from the dimmer switch. You can't push it as it's just hard plastic.
They are all hard plastic, have you tried pushing on it?
And, they are all single lamps at the rear center of the cab.
If the tradesman doesn't have this type of lamp, then I guess you could get one from a higher trim level truck and install it.
Discussion Starter #8
I don't think I have tried pushing it. I took my Harley to work today; I'll try it later. That would be cool if it had the push switch. I had passengers the other night looking for a light back there.
Discussion Starter #9
Terrible shot, taken during the process of installing Katzkin leather, but you can see the light above the passenger headrest in the shot:
Here's a pic of the one in my truck, on the driver side end of the lens is a "+" intended to indicate where to push on the lens to turn it on, but you can push on the middle as well.
I'd be very surprised if yours isn't just like this.
Discussion Starter #11
Well guys, mine doesn't have the push function. I have a well equipped Tradesman too, basically every Tradesman option. Here's a pic:
That's just ridiculous that RAM would do them that way.
Well, guess you can get a light assembly from a higher trim level and put it in there.
Discussion Starter #13
Anyone have a link to what I need online?
If I were you, go ahead and order an LED bulb as well and throw that in there before you mount it up.
Discussion Starter #16
Buyer of stuff..with OPM
I'd make sure there is a hot wire up there first, as the present light is wired through the door switch.....:confused013:
Sam
Sam
Not run through the door switch. Straight to the bcm. The bcm determines if the door is open to turn the light on. Otherwise the on off switch on the light itself is a simple switch and a function of the light fixture itself.
Regardless of where the power comes from (door switch/bcm etc.) won't new light need always on power to the switch to operate with the doors closed?
Sam
Sam
There’s two driver wires to the rear dome lamp. The courtesy lamp driver, which turns the lights on when the doors are opened, and the reading lamps driver, which is what makes the map lights come on when you press them. If the overhead console is present (which I already know he has), then the reading lamps driver wire is already present on the headliner harness connector for the rear dome lamp.
1 - 20 of 20 Posts
